capsman ccr1009-7g with cAP AX
There is a ccr1009-7g as a capsman server, everything works fine with a 5g network.
I bought myself a new access point mikrotik cAP AX - and cant connect to ccr1009-7g to capsman becasue in router i cant find AX chanels.
I read that need extra package wifiwave2 , but at the https://mikrotik.com/download when i download extra pack for TILE , inside i cant find package wifiwave2. Pls help how to set up it or where i can find extra pack for ccr1009-7g
Should be default there if you have ROS 7.13 or higher, under wifi menu.
i add screenshot , pls look. you can find that i dont have it!
No - ax to choose
with access point AC - work very good
For ax radios you can’t use old CAPsMAN. All settings are under WiFi menu
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-WiFiCAPsMAN
It is possible to use both CAPsMANs , old and new, on one device.
How to add it correctly to the general network (сcapsman or other name service) so that there is seamless roaming and not a separate access point?
You can have both capsman versions on the same controller.
You can not have seamless roaming between both controllers.
It is what it is.
OR Phuck capsman, especially if the capaX is the only MT wifi in the house. The complexity in the config for one device ( besides no gain over the sane non-capsman method) IMHO is just a plain dumb idea.
