I have :
- A full working RB1100x4 (stable 6.49.6) running as CAPsMAN manager dan Internet Gateway
- Seven RBcAPGi-5acD2nD (stable 6.49.6) running as CAP.
CAPsMAN running with no forwarding and enable client to client forwading.
The problem is clients suddenly cannot access the internet gateway. Client cannot ping the gateway but they exist at Registration Table.
I have to disconnect and connect several time so client can access the gateway again.
Some times, at DHCP lease, some client struggle with offering IP.
The problem not exist while running without CAPsMAN with SAME config (channel, tx-power, SSID).
here is my CAPsMAN config:
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=eC frequency=2472 name=2.4widebandch11 tx-power=16
add band=2ghz-g/n control-channel-width=20mhz extension-channel=Ce frequency=2412 name=2.4widebandch01 tx-power=16
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2462 name=2.4narrowband11 tx-power=16
add band=5ghz-n/ac control-channel-width=20mhz frequency=5765 name=channel5-153 tx-power=18
add band=5ghz-n/ac control-channel-width=20mhz frequency=5785 name=channel5-157 tx-power=18
add band=5ghz-n/ac control-channel-width=20mhz frequency=5825 name=channel5-165 tx-power=18
add band=5ghz-n/ac control-channel-width=20mhz frequency=5745 name=channel5-149 tx-power=18
add band=5ghz-n/ac control-channel-width=20mhz frequency=5805 name=channel5-161 tx-power=18
/caps-man datapath
add client-to-client-forwarding=yes l2mtu=1600 local-forwarding=yes name=datapath1
/caps-man configuration
add country=indonesia datapath=datapath1 installation=any mode=ap name="XXX_2.4" ssid="XXX"
add country=indonesia datapath=datapath1 name=XXX5G ssid=XXX5G
/caps-man interface
add channel=2.4widebandch01 configuration="XXX_2.4" disabled=no l2mtu=1600 mac-address=DC:2C:6E:6A:77:E2 master-interface=none name=cap_Accounting \
radio-mac=DC:2C:6E:6A:77:E2 radio-name=DC2C6E6A77E2
add channel=channel5-149 configuration=XXX5G disabled=no l2mtu=1600 mac-address=DC:2C:6E:6A:77:E3 master-interface=none name=cap_Accounting_5G radio-mac=\
DC:2C:6E:6A:77:E3 radio-name=DC2C6E6A77E3
add channel=2.4widebandch11 configuration="XXX_2.4" disabled=no l2mtu=1600 mac-address=DC:2C:6E:0D:EA:28 master-interface=none name=cap_Cutting \
radio-mac=DC:2C:6E:0D:EA:28 radio-name=DC2C6E0DEA28
add channel=channel5-165 configuration=XXX5G disabled=no l2mtu=1600 mac-address=DC:2C:6E:0D:EA:29 master-interface=none name=cap_Cutting_5G radio-mac=\
DC:2C:6E:0D:EA:29 radio-name=DC2C6E0DEA29
add channel=2.4widebandch01 configuration="XXX_2.4" disabled=no l2mtu=1600 mac-address=2C:C8:1B:C1:41:E4 master-interface=none name=cap_Gd.Roll \
radio-mac=2C:C8:1B:C1:41:E4 radio-name=2CC81BC141E4
add channel=channel5-161 configuration=XXX5G disabled=no l2mtu=1600 mac-address=2C:C8:1B:C1:41:E5 master-interface=none name=cap_Gd.Roll_5G radio-mac=\
2C:C8:1B:C1:41:E5 radio-name=2CC81BC141E5
add channel=2.4narrowband11 configuration="XXX_2.4" disabled=no l2mtu=1600 mac-address=48:8F:5A:17:56:BA master-interface=none name=cap_Marketing \
radio-mac=48:8F:5A:17:56:BA radio-name=488F5A1756BA
add channel=channel5-153 configuration=XXX5G disabled=no l2mtu=1600 mac-address=48:8F:5A:17:56:BB master-interface=none name=cap_Marketing_5G radio-mac=\
48:8F:5A:17:56:BB radio-name=488F5A1756BB
add channel=2.4widebandch11 configuration="XXX_2.4" disabled=no l2mtu=1600 mac-address=2C:C8:1B:C8:31:2A master-interface=none name=cap_PPIC radio-mac=\
2C:C8:1B:C8:31:2A radio-name=2CC81BC8312A
add channel=channel5-157 configuration=XXX5G disabled=no l2mtu=1600 mac-address=2C:C8:1B:C8:31:2B master-interface=none name=cap_PPIC_5G radio-mac=2C:C8:1B:C8:31:2B \
radio-name=2CC81BC8312B
/caps-man rates
add basic=9Mbps ht-basic-mcs=mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs=mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15 name=\
rate2.4 supported=9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-supported-mcs=""
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm,tkip name=security1 passphrase=xxxxx!
/caps-man manager
set enabled=yes
here is config without CAPsMAN at CAP
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-eC country=indonesia disabled=no frequency=2472 mode=ap-bridge ssid="XXX" tx-power=\
16 tx-power-mode=all-rates-fixed wps-mode=disabled
# managed by CAPsMAN
# channel: 5785/20-eCee/ac(15dBm), SSID: Sekawan5G, local forwarding
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee disabled=no frequency=5580 mode=ap-bridge ssid=Sekawan5G wps-mode=disabled
/interface wireless cap
set bridge=bridgeLocal caps-man-addresses=192.168.23.1 discovery-interfaces=bridgeLocal enabled=yes interfaces=wlan2
Please help. Thank You
