Capsman - config to keep cap up when capsman connection lost
I am using capsman in datacenter with mAP in a remote location. Works perfectly. How can I configure the cap to remain operational when connectivity to the capsman is lost for an extended period. (local forwarding is enabled) Thank you.
Yes, I would like to know this info also.
I’m pretty sure you can’t.
Currently, a CAP cannot run when its connection to CAPsMAN breaks, dot.
The maximum you can do is to enable a local CAPsMAN on the mAP and synchronize its configuration from the big one using a script, so if you do any changes at the big one, you don’t need to copy them to the mAP manually.
