capsman configuration with AP ubiquiti
Hello guys, i need to setup up a hotspot with router os but after i really want to know if access point ubiquiti (UNIFI) is compatible with capsman router os, if is the right configuration, i have the following scenario:
1x RB2011iL
4x UNIFI AP
is possible configure UNIFI to work with RB ?
thanks
Requirements
CAP device should have at least Level4 RouterOS license
only for four devices, is the controller really needed?
maybe this will help you :
https://www.ubnt.com/unifi/unifi-cloud-key/
Or just install the free local controller software and run it on a pc. I did that and port forwarded it in my Mikrotik so now I can access the GUI from the web, similar to how a “cloud key” would operate
Did you come right? I also want to know.
