I have 2 problems with Capsman.
I have 3 dual AP managing via gw (capsman). Id like to add 5GHz ap too but I cant via winbox and if I`d try interface wireless cap set interfaces=wlan2 I disable wlan1 in this RB.
I have latest 6.45.3.
2nd question is how can I manage one AP from another config.
I tried it via mac
but AP took Config not Sklad.
And thelast questio…I have dual ap in the bridge (ether1,2, wlan1,2)…how can I set config for 2g and 5G if manager can see both ap with the same mac?
Edit. I added Common Name =Regexp and 3rd AP took the right config but I`m still not be able to config 5G APs.
My situation.
I have 3 duals AP, 1 and 2 with the same SSID, 3rd has another.
I have 4 config, 2G and 5G for 1,2 and 2G and 5G for 3rd AP (becouse another SSID)
I have a problem with 5G AP.
My provisioning.
If I try run interface wireless cap set interfaces=wlan2 enabled=yes, wlan`is disabled because ident problem.
09:00:54 caps,error removing stale connection [CC:2D:E0:97:B0:FC/19/52,Run,CAP-6
8B6DF820E] because of ident conflict with [CC:2D:E0:97:B0:FC/19/bd74,Join,CAP-63
B6DF820E]
09:00:54 caps,info [CC:2D:E0:97:B0:FC/19/bd74,Join,CAP-6348B6DF820E] joined, pro
des radio(s): CC:2D:E0:97:B0:FF
09:00:54 caps,info Wifi_sklad-1: selected channel 5600/20-Ceee/ac/DP(27dBm) (fix
09:01:06 caps,error removing stale connection [CC:2D:E0:97:B0:FC/19/bd74,Run,CAP
348B6DF820E] because of ident conflict with [CC:2D:E0:97:B0:FC/19/d9c5,Join,CAP-
48B6DF820E]
09:01:06 caps,info [CC:2D:E0:97:B0:FC/19/d9c5,Join,CAP-6348B6DF820E] joined, pro
des radio(s): CC:2D:E0:97:B0:FE
09:01:06 caps,info Wifi_sklad-1: selected channel 2412/20-Ce/gn(20dBm) (saved)
