I have clients that are not able to complete a speed test due to the upload failing. The download works great, affected clients are also unable to browse. Hoping someone could provide some input. Here is my config. As a workaround I have enabled Local Forwarding on the datapath1 and this resolves the issue.
# sep/13/2019 12:02:11 by RouterOS 6.45.6
# software id =
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=Ce \
frequency=2412 name=channel1
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2442 name=channel6
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2472 name=channel11
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=Ceee \
frequency=5180 name=channel157
add comment="Primary LAN Bridge" name=PrimaryLan
set [ find default-name=ether1 ] auto-negotiation=no comment=WAN-DHCP \
disable-running-check=no speed=1Gbps
set [ find default-name=ether2 ] comment=LAN disable-running-check=no
/caps-man datapath
add bridge=PrimaryLan local-forwarding=yes name=datapath1
/caps-man security
add authentication-types=wpa2-psk comment= encryption=aes-ccm name=\
2.4
add authentication-types=wpa2-psk comment= encryption=aes-ccm name=5
/caps-man configuration
add channel=channel1 country="united states3" datapath=datapath1 mode=ap \
name=config1 security=2.4 ssid=Mikrotik-Test
add channel=channel157 country="united states3" datapath=datapath1 name=\
config2 security=2.4 ssid=test5
/caps-man interface
add arp=enabled channel=channel157 configuration=config2 datapath=datapath1 \
disabled=no l2mtu=1600 mac-address=CC:2D:E0:1D:6A:BA master-interface=\
none mtu=1500 name=cap3 radio-mac=CC:2D:E0:1D:6A:BA radio-name=\
CC2DE01D6ABA
add name=WAN
add name=LAN
add name=PrimaryLan ranges=192.168.2.90-192.168.2.200
add address-pool=PrimaryLan disabled=no interface=PrimaryLan name=PrimaryLan
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=config1 name-format=\
prefix name-prefix=Mikrotik-
add action=create-dynamic-enabled master-configuration=config2 name-format=\
prefix name-prefix=Mikrotik- radio-mac=CC:2D:E0:1D:6A:BB
add bridge=PrimaryLan interface=ether2
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=PrimaryLan list=LAN
add address=192.168.2.1/24 interface=PrimaryLan network=192.168.2.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.2.0/24 dns-server=192.168.2.1,1.1.1.1 gateway=192.168.2.1 \
netmask=24
set allow-remote-requests=yes servers=192.168.2.1
/ip dns static
add address=192.168.2.6 name=nextcloud.warllo.org
add address=192.168.2.6 name=ha.warllo.rog
add address=192.168.2.6 name=vpn.warllo.org
add address=192.168.2.6 name=dock.warllo.org
add address=192.168.2.6 name=plex.warllo.org
add address=192.168.2.6 name=collabora.warllo.org
add address=192.168.2.6 name=fire.warllo.org
add address=192.168.2.6 name=graph.warllo.org
add address=192.168.2.6 name=jelly.warllo.org
add address=192.168.2.6 name=vsc.warllo.org
add address=192.168.2.6 name=dockera.warllo.org
/ip firewall address-list
add address=192.168.2.2-192.168.2.254 list=allowed_to_router
"DEFAULT: Accept established, related, and untracked traffic." \
add action=accept chain=input comment="DEFAULT: Accept ICMP traffic." log=yes \
protocol=icmp
add action=drop chain=input comment="DEFAULT: Drop invalid traffic." \
connection-state=invalid
"DEFAULT: Drop all other traffic not coming from LAN." in-interface-list=\
!LAN
add action=drop chain=forward comment="DEFAULT: Drop invalid traffic." \
"DEFAULT: Drop all other traffic from WAN that is not DSTNATed." \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment="HTTP to Web Server" dst-port=80 \
in-interface=ether1 protocol=tcp to-addresses=192.168.2.6 to-ports=80
add action=dst-nat chain=dstnat comment="HTTPS to Web Server" dst-port=443 \
in-interface=ether1 protocol=tcp to-addresses=192.168.2.6 to-ports=443
add action=dst-nat chain=dstnat comment="OVPN to AS Server" dst-port=1194 \
in-interface=ether1 protocol=udp to-addresses=192.168.2.6 to-ports=1194
add action=dst-nat chain=dstnat comment="OPVNAS Web Interface" dst-port=943 \
in-interface=ether1 protocol=tcp to-addresses=192.168.2.6 to-ports=943
add action=dst-nat chain=dstnat comment="Plex to Plex Server" dst-port=32400 \
in-interface=ether1 protocol=tcp to-addresses=192.168.2.6 to-ports=32400
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api-ssl disabled=yes
/ip smb users
add name=warllo read-only=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=PrimaryLan type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=America/Chicago
/system logging
add action=disk topics=firewall
/system ntp client
set enabled=yes primary-ntp=216.239.35.0 server-dns-names=time.google.com
