Hallo,
i changed the configuration. The ip address is now on the bridge for the two caps.
now the client is getting an ip adress from the range 192.168.89.110 till 192.168.89.119. i can ping the caps ip address 192.168.89.1. but i had no access to the routers, the DNS Servers or internet... i can only ping the caps but nothing else.
i try with and without the local forwarding checkbox. no route to anything.
any idea?
export file from CAPsMAN Manager:
sep/28/2015 11:00:28 by RouterOS 6.32.1
software id = 58DW-EGDR
/caps-man configuration
add channel.extension-channel=Ce channel.frequency=2432 comment=
"Konfiguration zum Testen Mitarbieternetz" country=germany
datapath.local-forwarding=yes mode=ap name=cfg_cap-APs_Work
security.authentication-types=wpa-psk,wpa2-psk security.encryption=
aes-ccm security.passphrase=Contargo2015 ssid=Spucknapf
add name=bridge_CAPsMAN
set [ find default-name=ether2 ] name=LAN-vmnet3 speed=100Mbps
set [ find default-name=ether1 ] name=vmnet-bridge speed=100Mbps
/caps-man interface
add arp=enabled configuration=cfg_cap-APs_Work disabled=no l2mtu=1600
mac-address=E4:8D:8C:10:19:C0 master-interface=none mtu=1500 name=
cap1-AP12 radio-mac=E4:8D:8C:10:19:C0
mac-address=E4:8D:8C:15:3D:37 master-interface=none mtu=1500 name=
cap1-AP13 radio-mac=E4:8D:8C:15:3D:37
/ip dhcp-server option
add code=1 name=option1
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=hs-pool-1 ranges=192.168.99.1-192.168.99.253
add name=dhcp_pool1 ranges=192.168.88.210-192.168.88.220
add name=dhcp_pool2 ranges=192.168.89.210-192.168.89.220
add name=dhcp_pool3 ranges=192.168.89.210-192.168.89.219
add name=dhcp_pool4 ranges=192.168.89.100-192.168.89.149
add name=dhcp_pool5 ranges=192.168.89.100-192.168.89.119
add name=dhcp_pool6 ranges=192.168.89.70-192.168.89.79
add name=dhcp_pool7 ranges=192.168.89.100-192.168.89.119
add address-pool=dhcp_pool7 disabled=no interface=bridge_CAPsMAN name=
dhcp-CAPsMAN
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
add bridge=bridge_CAPsMAN interface=cap1-AP12
add bridge=bridge_CAPsMAN interface=cap1-AP13
add address=172.28.28.5/24 interface=LAN-vmnet3 network=172.28.28.0
add address=192.168.88.254/24 interface=vmnet-bridge network=192.168.88.0
add address=192.168.89.1/24 interface=bridge_CAPsMAN network=192.168.89.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
add address=192.168.89.0/24 dns-server=192.168.89.11 gateway=192.168.89.11
set allow-remote-requests=yes servers=192.168.88.10
/ip dns static
add address=192.168.88.1 name=router
add action=log chain=input connection-state=established,related,new disabled=
yes
add chain=input connection-state=established,related,new
add action=log chain=forward connection-state=established,related,new
disabled=yes
add chain=forward connection-state=established,related,new
add action=log chain=output connection-state=established,related,new
disabled=yes
add chain=output connection-state=established,related,new
yes
disabled=yes
disabled=yes
add action=masquerade chain=srcnat out-interface=bridge_CAPsMAN
/ip ipsec policy
set 0 disabled=yes
/ip proxy
set anonymous=yes cache-path=disk1/web-proxy1 enabled=yes parent-proxy=
0.0.0.0
add distance=1 gateway=192.168.88.10
add distance=1 dst-address=192.168.89.0/24 gateway=192.168.88.251
/ip service
set api disabled=yes
/ip smb
set domain=poke.mon enabled=yes
/radius
add address=172.16.1.2 called-id=Aloisius01 secret=aloiGeheimXX service=
hotspot timeout=600ms
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Berlin
/system identity
set name=CAPsMAN
/system ntp client
set enabled=yes primary-ntp=172.27.27.1
/system package update
set channel=current
/tool graphing interface
add
add
/tool romon port
add
greetings
Stephan, the ruebenmaster
