I have a problem with capsman, i have a configuration with 3 SSID and 3 Vlans, each one has a DHCP server. One of the SSID is a guest network so i dont want that the users of this network has any possibility to connect to the local network, i want to isolate this network from the others (wired and wifi).
i read that i must to configure in the datapath section of capsman the local forwarding option, but when i do that nothing happends, i try to make a ping to the server (is in another network) and it works (i dont want that).
I can do that with the firewall but i dont want to load the cpu if i can do with an easy configuration.
I attach my datapath configuration.
