I have WAPac access points configured with CAPsMAN from a RB750Gr3. A standard configuration like in the wiki is working.
I want to restrict the 2.4 G radio on all access points (20 MHz width, no extension channel) because of the crowded environment. The 5 G radio on the access points shouldn’t be restricted.
My own attempts at this have failed, see below:
# jul/18/2018 13:05:44 by RouterOS 6.42.6
# software id = RN48-R360
# model = RouterBOARD 750G r3
# serial number = XXXXXXXXXXXX
/caps-man configuration
add channel.band=2ghz-g/n channel.extension-channel=disabled comment="Restrict\
\_2.4G to g and n; disable extension channel for crowded environment" \
name=config2.4G
add admin-mac=6C:3B:6B:AA:6F:37 auto-mac=no comment=defconf name=bridge
add channel.skip-dfs-channels=no comment=\
"Basic configuration for 2 APs with CapsMan" country=germany \
datapath.bridge=bridge name=EMKhome security.authentication-types=\
wpa-psk,wpa2-psk security.passphrase=XXXXXXXXXXXXXXXX ssid=EMKnet
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/caps-man manager
set enabled=yes upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled comment="Standard config" \
master-configuration=EMKhome
add action=create-dynamic-enabled comment=\
"Add 2.4G extra configurations for 2.4G radios" disabled=yes \
hw-supported-modes=g master-configuration=EMKhome slave-configurations=\
config2.4G
192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
/system identity
set name=RB750Gr3
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
What am I doing wrong here?
