Hello @all
we´re currently trying to solve the following problem:
I got a CAPsMAN which is working fine, we´ve got some CAPs provisioned by it and all looks good.
Now we´d like to disable the WIFI on all CAPs provisioned by this CAPsMAN zentralized so we don´t have to access each wAP device seperately.
The WIFI has to be disabled or removed. It should not be accessible and it should not keep broadcasting its SSID, else I could simply turn on a firewall rule and block all the packets but this will confuse the customers.
Does someone have a clue if this is possible at all and if so a quick hint into the right direction would be very appreciated.
Thank you in advance,
Fabian
