Question about running CAPSMAN as well as Dynamic Mesh. I am using cAP AC devices with duel radios.
I am considering setting up CAPsMAN with 9 AP’s, hardwiring them, and also configuring Dynamic Mesh on top of it for failover if the cable fails. I understand that with everything running on the same channel I will have a lot of interference so throughput would be affected.
It is my understanding that RSTP will prevent loops in these types of setups. Will it automatically use the fastest connection when available meaning the hard wire or do I need to write a script that enables WDS on link failure?
Does anybody foresee an issues with doing it this way.
Any suggestions on this setup, shortcomings, or pitfalls I may run into trying to pull this off?
Thanks for any suggestions you may have.
