Hello fellas.
We are trying to setup mikrotik device in enterprise environment (eduroam). We solved dynamic vlans using CapsMan, but now we have trouble with accouting. In regular setup without capsman, there are options to use EAP accouting and to set update interval, but we can’t seem to find that option in capsman. We tried setting accouting via access list, but that gives us MAc accouting, and it does not update in regular intervals.
There is option to use EAP accouting and to set interim update in wireless/security profiles, but I can’t seem to find equivalent in capsman.
So my question is, is EAP accouting supported in CapsMan (using username from access-accept)? If so, how would one go about configuring it? Also, interim update interval?
Capsman version is 2, routeros version is 6.27.
Thanks.
