CAPSMAN: error removing stale connection
hi there,
i got the instalation with 9 audiences, the first unit act as caps manager and caps while other 8 units as caps
the problem is the caps unit 7 and 9 always intermitent (come up and disappear)
the error on the capsman as follows :
caps,error removing stale connection [74:4D:28:F7:8A:21/5/ff71,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:AD/5/7a69,Join,[76:4D:28:F7:8A:21]]
caps,error removing stale connection [74:4D:28:F7:8A:AD/5/7fd0,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:21/5/ff71,Join,[76:4D:28:F7:8A:21]]
caps,error removing stale connection [74:4D:28:F7:8A:21/5/ff71,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:AD/5/1849,Join,[76:4D:28:F7:8A:21]]
caps,error removing stale connection [74:4D:28:F7:8A:AD/5/7fd0,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:21/5/2b74,Join,[76:4D:28:F7:8A:21]]
caps,error removing stale connection [74:4D:28:F7:8A:21/5/ff71,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:AD/5/a6d1,Join,[76:4D:28:F7:8A:21]]
caps,error removing stale connection [74:4D:28:F7:8A:AD/5/7fd0,Run,[76:4D:28:F7:8A:21]] because of ident conflict with [74:4D:28:F7:8A:21/5/9400,Join,[76:4D:28:F7:8A:21]]
the end error log always “Join,[76:4D:28:F7:8A:21]” even if the original mac address of bridge is different.
the /system identity of those two units surely different
can anyone point me the problem cause ?
thank you
Paul
On AP check:
  • bridge
  • General
  • Admin. MAC Address
If there is a specified MAC, remove it.
