Capsman Forwarding HAP-AC2?
Is Capsman forwarding supposed to work with Spanning Tree enabled on the bridge?
If forwarding is set in a datapath config I cannot get it to work, in either Capsman or local forwarding.
If I set local forwarding in the datapath config under a configuration (Capsman > Configurations > select configuration > Datapath tab in winbox) then that works with Spanning Tree enabled.
7.1b2 although seen this in other 7.x beta releases, could well be something odd with my config.
Disabling Spanning tree on the bridge seems to fix the problems with capsman forwarding.
