I have a L009UiGS-2HaxD-IN which is replacing my RB2011UiAS-2HnD. I have CAPsMAN setup on the RB2011(controller) with two hAP ac lites controlled by CAPsMAN. From what I found in the documentation the hAP ac lites won’t be able to be controlled by CAPsMAN on the new L009 because of the router OS changes on L009, but I’m not 100% sure.
Can I still control the hAP ac lites with CAPsMAN on the L009 or does this mean I need to upgrade to the hAP ax lite with router OS 7?
Since 7.13 you can use old capsman on L009 if you load wireless package and remove wifi-qcom.
But then you loose the wireless radio on L009 (wireless package is not compatible with AX radio).
And I guess you also have a use for that one since your 2011 also had a radio ?
