Capsman Host cannot see host
I have 2 SSID on capsman 1 for Lan and 1 for Guest , i have problem accessing devices that are connected to LAN SSID from another device that is connected to the SAME ssid , if its connected on the wire LAN its fine ,
basicaly is a kind of AP isolation , is there any way to disable or a way to access device on same network ?
Enable client to client forwarding in Capsman datapath.
