Hi everyone,
Could somebody can help me.. I setup main AP to be CAPsMAN manager and all other to be CAP client.
My setup:
1x RouterBOARD 750G r2 @ 6.40.3 (Main router)
2x wAP G-5HacT2HnD @ 6.40.3 (My two AP, one CAPsMAN Manager and the other fresh from factory except firmware, booted into CAP)
Two problem:
I did not see any SSID, I see blank ssid with wifi scanner but unable to plug to it.. I want to see both ssid, one for 2.4 and one for 5.
The other problem is probably my bad, I can’t access to it in Winbox, but I see it.
But provisionning seem to work so far…
Here the config export sensitive hide of the “main” AP with CAP Manager enabled. I don’t want to complicated setup with certificate.. it’s for home purpose…
# sep/07/2017 21:26:07 by RouterOS 6.40.3
# software id = RUBG-70EA
# model = RouterBOARD wAP G-5HacT2HnD
# serial number = 774906A37XXX
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412 name=channel1
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2437 name=channel6
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2462 name=channel11
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5180 name=\
channel36
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5240 name=\
channel48
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5320 name=\
channel64
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5720 name=\
channel144
add band=5ghz-a/n/ac control-channel-width=20mhz frequency=5745 name=\
channel149
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled arp-timeout=auto \
auto-mac=yes comment=defconf disabled=no fast-forward=yes forward-delay=\
15s max-message-age=20s mtu=auto name=bridge priority=0x8000 \
protocol-mode=rstp transmit-hold-count=6
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled \
arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no full-duplex=yes l2mtu=1600 loop-protect=default \
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
6C:3B:6B:B7:0B:46 master-port=none mtu=1500 name=ether1 orig-mac-address=\
6C:3B:6B:B7:0B:46 rx-flow-control=off speed=100Mbps tx-flow-control=off
/caps-man interface
add arp-timeout=auto disabled=no l2mtu=1600 mac-address=6C:3B:6B:B7:0B:47 \
master-interface=none name=cap1 radio-mac=6C:3B:6B:B7:0B:47
add arp-timeout=auto disabled=no l2mtu=1600 mac-address=6C:3B:6B:B7:0B:48 \
master-interface=none name=cap2 radio-mac=6C:3B:6B:B7:0B:48
add arp-timeout=auto disabled=no l2mtu=1600 mac-address=6C:3B:6B:76:ED:8C \
master-interface=none name=cap3 radio-mac=6C:3B:6B:76:ED:8C
add arp-timeout=auto disabled=no l2mtu=1600 mac-address=6C:3B:6B:76:ED:8B \
master-interface=none name=cap4 radio-mac=6C:3B:6B:76:ED:8B
/ip neighbor discovery
set ether1 discover=no
set bridge discover=yes
set cap1 discover=yes
set cap2 discover=yes
set cap3 discover=yes
set cap4 discover=yes
/queue interface
set bridge queue=no-queue
set cap1 queue=no-queue
set cap2 queue=no-queue
set cap3 queue=no-queue
set cap4 queue=no-queue
/caps-man datapath
add bridge=bridge name=datapath1
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=ultrasecure
/caps-man configuration
add channel=channel1 datapath=datapath1 mode=ap name=configuration security=\
ultrasecure ssid=Tabarnak
add channel=channel149 datapath=datapath1 mode=ap name=configuration5 \
security=ultrasecure ssid=Tabarnak5
set [ find name=all ] name=all
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=disabled mode=none mschapv2-username="" name=\
default radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled \
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
none static-sta-private-algo=none static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=\
no-certificates unicast-ciphers=aes-ccm
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(30dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
0 area="" arp=enabled arp-timeout=auto band=2ghz-b/g/n basic-rates-a/g=\
6Mbps basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-Ce \
compression=no country=no_country_set default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=\
yes disable-running-check=no disabled=yes disconnect-timeout=3s distance=\
indoors frame-lifetime=0 frequency=auto frequency-mode=manual-txpower \
frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=7 interworking-profile=disabled \
keepalive-frames=enabled l2mtu=1600 mac-address=6C:3B:6B:B7:0B:48 \
max-station-count=2007 mode=ap-bridge mtu=1500 multicast-buffering=\
enabled multicast-helper=default name=wlan1 noise-floor-threshold=default \
nv2-cell-radius=30 nv2-downlink-ratio=50 nv2-mode=dynamic-downlink \
nv2-noise-floor-offset=default nv2-qos=default nv2-queue-count=2 \
nv2-security=disabled nv2-sync-secret="" on-fail-retry-time=100ms \
preamble-mode=both radio-name=6C3B6BB70B48 rate-selection=advanced \
rate-set=default rx-chains=0,1 scan-list=default security-profile=default \
ssid=MikroTik-B70B48 station-bridge-clone-mac=00:00:00:00:00:00 \
station-roaming=enabled supported-rates-a/g=\
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0,1 \
tx-power-mode=default update-stats-interval=disabled vlan-id=1 vlan-mode=\
no-tag wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
wds-ignore-ssid=no wds-mode=disabled wireless-protocol=802.11 \
wmm-support=disabled wps-mode=push-button
# channel: 5745/20-Ceee/ac(30dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=\
0 area="" arp=enabled arp-timeout=auto band=5ghz-a/n/ac basic-rates-a/g=\
6Mbps bridge-mode=enabled channel-width=20/40/80mhz-Ceee compression=no \
country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes disable-running-check=no \
disabled=yes disconnect-timeout=3s distance=indoors frame-lifetime=0 \
frequency=auto frequency-mode=manual-txpower frequency-offset=0 \
keepalive-frames=enabled l2mtu=1600 mac-address=6C:3B:6B:B7:0B:47 \
enabled multicast-helper=default name=wlan2 nv2-cell-radius=30 \
nv2-downlink-ratio=50 nv2-mode=dynamic-downlink nv2-qos=default \
nv2-queue-count=2 nv2-security=disabled nv2-sync-secret="" \
on-fail-retry-time=100ms preamble-mode=both radio-name=6C3B6BB70B47 \
rate-selection=advanced rate-set=default rx-chains=0,1,2 scan-list=\
default security-profile=default ssid=MikroTik-B70B47 \
station-bridge-clone-mac=00:00:00:00:00:00 station-roaming=enabled \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
tdma-period-size=2 tx-chains=0,1,2 tx-power-mode=default \
update-stats-interval=disabled vht-basic-mcs=mcs0-7 vht-supported-mcs=\
mcs0-9,mcs0-9,mcs0-9 vlan-id=1 vlan-mode=no-tag wds-cost-range=50-150 \
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
disabled wireless-protocol=802.11 wmm-support=disabled wps-mode=\
push-button
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
set wlan1 discover=yes
set wlan2 discover=yes
/ip dhcp-client option
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
flash/hotspot html-directory-override="" http-cookie-lifetime=3d \
http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only
/ip ipsec policy group
set [ find default=yes ] name=default
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
modp1024
add address-pool=default-dhcp authoritative=yes bootp-support=static \
disabled=yes interface=wlan1 lease-script="" lease-time=10m name=defconf
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost \
!bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout \
!incoming-filter !insert-queue-before !interface-list !local-address \
name=default on-down="" on-up="" only-one=default !outgoing-filter \
!parent-queue !queue-type !rate-limit !remote-address !session-timeout \
use-compression=default use-encryption=default use-mpls=default use-upnp=\
default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost \
name=default-encryption on-down="" on-up="" only-one=default \
!outgoing-filter !parent-queue !queue-type !rate-limit !remote-address \
!session-timeout use-compression=default use-encryption=yes use-mpls=\
default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id \
!confederation disabled=no ignore-as-path-len=no name=default out-filter=\
"" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=\
no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id \
!domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 \
metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 \
!mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
!routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-protocol=MD5 \
encryption-protocol=DES name=public read-access=yes security=none \
write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=flash/log disk-lines-per-file=1000 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude" skin=\
default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude" skin=\
default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api,romon,dude,tikapp" skin=default
/caps-man aaa
set interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX \
/caps-man manager
set ca-certificate=none certificate=none enabled=yes package-path="" \
require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/caps-man provisioning
add action=create-dynamic-enabled common-name-regexp="" disabled=no \
hw-supported-modes="" identity-regexp="" ip-address-ranges="" \
master-configuration=configuration name-format=prefix name-prefix=\
tabarnak_ radio-mac=00:00:00:00:00:00 slave-configurations=""
add action=create-dynamic-enabled common-name-regexp="" disabled=yes \
master-configuration=configuration5 name-format=prefix name-prefix=\
calisse_ radio-mac=00:00:00:00:00:00 slave-configurations=""
/certificate settings
set crl-download=yes crl-use=yes
add auto-isolate=no bridge=bridge comment=defconf disabled=no edge=auto \
external-fdb=auto horizon=none interface=wlan1 path-cost=10 \
point-to-point=auto priority=0x80
external-fdb=auto horizon=none interface=wlan2 path-cost=10 \
add auto-isolate=no bridge=bridge disabled=no edge=auto external-fdb=auto \
horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=\
0x80
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d \
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
udp-stream-timeout=3m udp-timeout=10s
/ip neighbor discovery settings
set default=yes default-for-dynamic=no
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
yes send-redirects=yes tcp-syncookies=no
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 \
caller-id-type=ip-address default-profile=default-encryption enabled=no \
keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited \
mrru=disabled one-session-per-host=no use-ipsec=no
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=\
no keepalive-timeout=60 mac-address=FE:6D:E9:23:11:2C max-mtu=1500 mode=\
ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 \
max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any \
verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=bridge caps-man-addresses="" caps-man-certificate-common-names="" \
caps-man-names="" certificate=none discovery-interfaces=ether1 enabled=\
yes interfaces=wlan1,wlan2 lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.2/24 comment=defconf disabled=no interface=wlan1 \
network=192.168.1.0
/ip cloud
set ddns-enabled=no update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes comment=defconf default-route-distance=1 \
dhcp-options=hostname,clientid disabled=yes interface=bridge \
use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.1.0/24 caps-manager="" comment=defconf dhcp-option="" \
dns-server="" gateway=192.168.1.2 netmask=24 ntp-server="" wins-server=""
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB \
max-concurrent-queries=100 max-concurrent-tcp-sessions=20 \
max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s \
servers=8.8.8.8
/ip dns static
add address=192.168.1.2 disabled=no name=router regexp="" ttl=1d
add action=accept chain=input comment="defconf: accept established,related" \
# in/out-interface matcher not possible when interface (ether1) is slave - use master instead (bridge)
add action=drop chain=input comment="defconf: drop all from WAN" \
in-interface=ether1
add action=accept chain=forward comment="defconf: accept established,related" \
connection-state=invalid
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
out-interface=ether1 !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
all src-address=::/0 template=yes
/ip ipsec user settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
max-cache-object-size=2048KiB max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref \
!bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1 \
dst-address=0.0.0.0/0 gateway=192.168.1.1 !route-tag !routing-mark scope=\
30 target-scope=10
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/flash/pub \
disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set always-allow-password-login=no forwarding-enabled=no host-key-size=2048 \
strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=16k enabled=no \
inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=\
yes packets=yes protocol=yes src-address=yes src-address-mask=yes \
src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes \
tcp-seq-num=yes tcp-window-size=yes tos=yes ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public \
trap-generators="" trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=America/Toronto
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=AP2320
/system leds
set 0 disabled=no interface=wlan1 leds=wlan1-led type=wireless-status
set 1 disabled=no interface=wlan2 leds=wlan2-led type=wireless-status
set 2 disabled=no leds=cap-led type=ap-cap
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp \
force-backup-booter=no protected-routerboot=disabled \
reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set [ find default=yes ] disabled=yes interface=all
add disabled=no interface=bridge
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00 secrets=""
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all \
secrets=""
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
filter-interface="" filter-ip-address="" filter-ip-protocol="" \
filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" \
filter-operator-between-entries=or filter-port="" filter-stream=no \
memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes \
stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
Don’t laugh at my SSID folks
It’s Quebec swearing.. I getin very frustrated after 1 week to try out some recipies ![]()
Thanks to all!!
