Guys,
Testing CAPsMAN for a customer and we’ve found that the following devices will not connect to a CAPsMAN managed WAP however when the settings are replicated directly to the WAP the devices connect fine:
NG4F2ZP/A - iPhone 6 11.0.3
MG4H2X/A - iPhone 6 11.1.1
MLM72X/A - iPhone SE 11.0.3
We also found the following Android device fails to connect also.
OnePlus 3T. Android 7.1.1
Config:
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled \
frequency=2422 name="channel - 2422"
/caps-man datapath
add bridge=bridge-lan client-to-client-forwarding=yes local-forwarding=yes \
name=bridge-lan
/caps-man rates
add basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,\
48Mbps,54Mbps" ht-basic-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs\
-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs\
-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-supported-mcs="mcs-0,mcs-1,mcs-\
2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mc\
s-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" \
name="All Rates" supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,\
18Mbps,24Mbps,36Mbps,48Mbps,54Mbps"
/caps-man configuration
add channel="channel - 2422" country=australia datapath=bridge-lan \
disconnect-timeout=3s distance=indoors frame-lifetime=0ms \
hw-protection-mode=none hw-retries=7 keepalive-frames=enabled \
max-sta-count=2007 name=Customer-SSID rates="All Rates" rx-chains=0,1,2 \
security.authentication-types=wpa-psk,wpa2-psk security.encryption=\
aes-ccm security.group-encryption=aes-ccm security.group-key-update=1h \
security.passphrase=123456789 ssid=Customer-SSID tx-chains=0,1,2
