capsman Iphones lose connectivity
Hello, community,
I have a case where iPhone and ipad devices lose network connectivity (not signal) on a capsman network at random times.
Moreover suddenly somehow disconnect form wifi, but they show full wifi signal on screen, and can’t ping any IP, even local.
The connectivity is established again when the apple user is switching on and off the Private Address in Wifi network settings, as described in the following.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjO1ovD9O_8AhXuQ_EDHX7rCYMQFnoECBwQAw&url=https%3A%2F%2Fsupport.apple.com%2Fen-us%2FHT211227&usg=AOvVaw38ImIPSeeRr63y4d33pqM7
Probably this disconnects and reconnects the device.
Most caps are mAP and there are also GrooveA-52HpN for outdoor areas and just 2 mANTBox 52 15s in 2.4 and AC on different SSID for outdoor crowded areas.
The manager is on CCR1009-7G-1C-1S+.
All of them are on ros version 6.49.6
Can someone suggest a workaround for this?
My capsman config is:
/caps-man channel
add band=2ghz-b/g/n frequency=2412 name=CH1
add band=2ghz-b/g/n frequency=2417 name=CH2
add band=2ghz-b/g/n frequency=2422 name=CH3
add band=2ghz-b/g/n frequency=2427 name=CH4
add band=2ghz-b/g/n frequency=2432 name=CH5
add band=2ghz-b/g/n frequency=2437 name=CH6
add band=2ghz-b/g/n frequency=2442 name=CH7
add band=2ghz-b/g/n frequency=2447 name=CH8
add band=2ghz-b/g/n frequency=2452 name=CH9
add band=2ghz-b/g/n frequency=2457 name=CH10
add band=2ghz-b/g/n frequency=2462 name=CH11
add band=2ghz-b/g/n frequency=2467 name=CH12
add band=2ghz-b/g/n frequency=2472 name=CH13
add band=5ghz-a/n/ac frequency=5180 name=CH36
add band=5ghz-a/n/ac frequency=5200 name=CH40
add band=5ghz-a/n/ac frequency=5220 name=CH44
add band=5ghz-a/n/ac frequency=5240 name=CH48
add band=5ghz-a/n/ac frequency=5260 name=CH52
add band=5ghz-a/n/ac frequency=5280 name=CH56
add band=5ghz-a/n/ac frequency=5300 name=CH60
add band=5ghz-a/n/ac frequency=5320 name=CH64
add band=5ghz-a/n/ac frequency=5500 name=CH100
add band=5ghz-a/n/ac frequency=5520 name=CH104
add band=5ghz-a/n/ac frequency=5540 name=CH108
add band=5ghz-a/n/ac frequency=5560 name=CH112
add band=5ghz-a/n/ac frequency=5580 name=CH116
add band=5ghz-a/n/ac frequency=5600 name=CH120
add band=5ghz-a/n/ac frequency=5620 name=CH124
add band=5ghz-a/n/ac frequency=5640 name=CH128
add band=5ghz-a/n/ac frequency=5660 name=CH132
add band=5ghz-a/n/ac frequency=5680 name=CH136
add band=5ghz-a/n/ac frequency=5700 name=CH140
add band=5ghz-a/n/ac frequency=5745 name=CH149
add band=5ghz-a/n/ac frequency=5765 name=CH153
add band=5ghz-a/n/ac frequency=5785 name=CH157
add band=5ghz-a/n/ac frequency=5805 name=CH161
add band=5ghz-a/n/ac frequency=5825 name=CH165
/caps-man rates
add basic=12Mbps name="2.4gn only" supported=\
    12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=no encryption=aes-ccm \
    group-key-update=23h59m59s name=island_security
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=all \
    signal-range=-90..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=no interface=all \
    signal-range=-120..-91 ssid-regexp=""
/caps-man configuration
add channel.band=2ghz-g/n channel.control-channel-width=20mhz country=greece \
    datapath.bridge=CLIENT installation=indoor mode=ap multicast-helper=full \
    name=island_client_indoor security=island_security ssid=TheIsland
add channel.band=2ghz-g/n channel.control-channel-width=20mhz country=\
    no_country_set datapath.bridge=CLIENT installation=any mode=ap \
    multicast-helper=full name=island_client_nocountry security=\
    datapath.bridge=CLIENT installation=outdoor mode=ap multicast-helper=full \
    name=island_client_outdoor security=island_security ssid=TheIsland
add channel.band=5ghz-onlyac channel.skip-dfs-channels=yes country=greece \
    datapath.bridge=CLIENT installation=any mode=ap multicast-helper=full \
    name=island_client_AC security=island_security ssid=TheIsland_Faster
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/pub
/caps-man manager interface
add disabled=no forbid=yes interface=ether1-WAN
add disabled=no forbid=yes interface=ether7-CORP
/caps-man provisioning
add action=create-enabled hw-supported-modes=gn master-configuration=\
    island_client_indoor name-format=identity
add action=create-enabled hw-supported-modes=ac master-configuration=\
    island_client_AC name-format=identity
I have removed the caps-man interface because all caps are 271.
DHCP lease time is 1 day and authoritative.
ARP timeout is set to 4 hours.
If you want other parts of the config let me know.
