Hi Everyone,
I’m planning how to build NW infrastructure in my new apartment.
Outcome is to have ac wireless ( single SSID ), LAN and IPTV to all three rooms, transmitted over just one CAT6 cable( per room ).
Desired products are three “hAP ac2” managed by CAP Manager ( still don’t now what device but most probably “hEX S” ).
Reason behind using CAPsMAN is that I’ve just one physical NW cable to each room and all of them are collected far away from two of the rooms.
Currently testing with one “hAP ac2” and one “hAP Lite”. The “hAP ac2” is working as CAPs Manager for the “hAP lite”.
Following official documentation - https://wiki.mikrotik.com/wiki/Manual:Simple_CAPsMAN_setup - I was able to configure wireless section ( not ac one but at least is working ).
Assume that LAN is also working on “hAP lite” ( not tested ) as all ports on it are in the same bridge. Two points achieved from the desired setup.
And here is the tuff part - IPTV.
Only scenario in which I have both internet and TV is when I put WAN + STB ports on CAPsMAN router in different bridge ( bridgeTv )and also to change masquerade FW rule to point to all interfaces. However, in desired situation STB should be connected to CAP not to manager.
Can anyone share his opinion is it possible to passtrough IPTV via CAPsMAN ?
Regards,
Spas Zdravkov
