When I use the network interface directly, the wireless work is normal.
/interface wireless cap
set discovery-interfaces=bridge1 enabled=yes interfaces=wlan1
When I use the IPV4 address to connect, the wireless work is normal.
set caps-man-addresses=192.168.58.1 enabled=yes interfaces=wlan1
When I use the IPV6 address to connect, it just seems to be working. The wireless CAP can connect to the capsman, and the wireless client can connect, but the network is not working properly. It can be pinged and a dynamic IP address can be obtained, but no website can be accessed.
I think this is just a BUG, and hope to fix it in the version update.
set caps-man-addresses=2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4 enabled=yes interfaces=wlan1
logs:
17:48:48 caps,debug CAP None->Discover
17:48:48 caps,debug CAP discovery target list:
17:48:48 caps,debug 2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4:5246
17:48:48 system,info CAP configuration changed by admin
17:48:51 caps,debug CAP discovery over, results:
17:48:51 caps,debug AnTaiYuan (2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4:5246)
17:48:51 caps,debug CAP Discover->Select
17:48:51 caps,info CAP selected CAPsMAN AnTaiYuan (2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4:5246)
17:48:51 caps,debug CAP Select->Connect
17:48:53 caps,info CAP connected to AnTaiYuan (2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4:5246)
17:48:53 caps,debug CAP Connect->Join
17:48:53 caps,info CAP joined AnTaiYuan (2409:8a44:3051:ecc:4e5e:cff:fef0:1ca4:5246)
17:48:53 caps,debug CAP Join->Joined
console:
[admin@AnTaiYuan] /caps-man remote-cap> pri
# ADDRESS NAME STATE RADIOS
0 10.20.0.235/56387 [6C:3B:6B:76:8E:0A] Run 1
1 2409:8a44:3051:ec8:4e5e:cff:fef2:9402/42870 [4C:5E:0C:F2:94:02] Run 1
