CAPsMAN is it dynamic?
I want to use CAPsMAN to manage many AP’s in our network (with many VLANs.)
Our network is changing a lot.
So my question, is CAPsMAN dynamic?
If we change for example WPA2-PSK encryption in the CAPsMAN is it automatically pushed to to CAP clients?
Or de we need manual actions?
Yes, with Capsman you can push wireless AP settings to clients.
But i recommended make VLAN settings to WLAN AP because that eat less CPU and use local forwarding also.
Thanks a lot.
Sure I use VLANs for the ap’s, I use only virtual APs
I cant see very much thing to setup the AP in CAPsMAN.
IS there a good document to help me with CAPsMAN v2 and AP settings like dual band, N Only and AC only for example.
There have everything: http://wiki.mikrotik.com/wiki/Manual:CAPsMAN
You can make custom configuration what only allow N / AC, example 2.4Ghz configuration only N and 5Ghz only AC.
If you use Capsman forwarding you do not need set up VLAN’s to AP device. Capsman make own forwading default so it tunnel all to controller. Best speed you get if you use local forwading.
Thanks for you reply.
So in the AP’s I don’t have to add VLAN setup?
That is great.
I Only have to add the Management VLAN I think (All the devices are in one management VLAN).
No VLAN setup on ap if you use CAPsMAN sounds great, I will try it for sure.
I need to add “Use Tag” And VLAN ID in CAPsMAN setup I thinbk?
If you use Capsman forwarding it use tunnel to Capsman controller so capsman controller should have VLAN configured correctly. With local forwarding you need configure to all AP VLAN settings.
Yes, you should add management VLAN to all AP so easier manage and IP-address.
Yes add VLAN id and interface what you like use (interface is same as Capsman controller) example bridge-trunk where you have all VLAN and then tag VLAN.
Hi, I’m still struggeling with setting up my test environment with CAPsMAN.
Is it possible to post my config?
Why not? include both CAPS and CAPsMan exports..
Ok, here is my configs.
Problems with getting a DHCP lease.
I the DHCP server I see offer but no accept (bond).
Hope someone can see what is wrong.
I also try to set the parameter for "Local Forwarding" but this makes no difference.
First is from the CAPsMAN.
Maak VLANs
/interface vlan
add name=VLAN_LAN_MGMT interface=ether5 vlan-id=9
add name=VLAN_LAN_DATA interface=ether5 vlan-id=10
add name=VLAN_WLAN_DATA interface=ether5 vlan-id=12
add name=VLAN_WLAN_GUEST interface=ether5 vlan-id=14
add name=VLAN_LAN_MFP interface=ether5 vlan-id=15
add name=VLAN_LAN_GAME interface=ether5 vlan-id=16
add name=VLAN_LAN_CAMERA interface=ether5 vlan-id=17
add name=VLAN_LAN_TVMM interface=ether5 vlan-id=18
add name=VLAN_WLAN_SP interface=ether5 vlan-id=19
add name=VLAN_LAN_SERVER interface=ether5 vlan-id=900
Bridge toevogen
add name=BR_LAN_MGMT
add name=BR_WLAN_DATA
add name=BR_WLAN_GUEST
add name=BR_LAN_MFP
add name=BR_LAN_GAME
add name=BR_LAN_CAMERA
add name=BR_LAN_TVMM
add name=BR_WLAN_SP
Poorten toevoegen aan een bridge
add bridge=BR_LAN_MGMT interface=ether1
add bridge=BR_LAN_MGMT interface=VLAN_LAN_MGMT
add bridge=BR_WLAN_DATA interface=VLAN_WLAN_DATA
add bridge=BR_WLAN_GUEST interface=VLAN_WLAN_GUEST
add bridge=BR_LAN_MFP interface=VLAN_LAN_MFP
add bridge=BR_LAN_GAME interface=VLAN_LAN_GAME
add bridge=BR_LAN_CAMERA interface=VLAN_LAN_CAMERA
add bridge=BR_LAN_TVMM interface=VLAN_LAN_TVMM
add bridge=BR_WLAN_SP interface=VLAN_WLAN_SP
IP adressen toewijzen
add address=172.16.0.1/25 network=172.16.0.0 interface=BR_LAN_MGMT
add address=172.16.1.1/24 network=172.16.1.0 interface=VLAN_LAN_DATA
add address=172.16.2.1/24 network=172.16.2.0 interface=BR_WLAN_DATA
add address=172.16.3.1/24 network=172.16.3.0 interface=BR_WLAN_GUEST
add address=172.16.4.1/26 network=172.16.4.0 interface=BR_LAN_MFP
add address=172.16.4.129/25 network=172.16.4.128 interface=BR_LAN_GAME
add address=172.16.5.1/25 network=172.16.5.1 interface=BR_LAN_CAMERA
add address=172.16.5.126/25 network=172.16.5.128 interface=BR_LAN_TVMM
add address=172.16.6.1/24 network=172.16.6.0 interface=BR_WLAN_SP
add address=172.16.0.129/27 network=172.16.0.128 interface=VLAN_LAN_SERVER
DHCP Pools toevoegen
add name=POOL_LAN_DATA ranges=172.16.1.2-172.16.1.253
add name=POOL_WLAN_DATA ranges=172.16.2.1-172.16.2.253
add name=POOL_WLAN_GUEST ranges=172.16.3.1-172.16.3.253
add name=POOL_LAN_MFP ranges=172.16.4.1-172.16.4.125
add name=POOL_LAN_GAME ranges=172.16.4.130-172.16.4.253
add name=POOL_LAN_CAMERA ranges=172.16.5.1-172.16.5.125
add name=POOL_LAN_TVMM ranges=172.16.5.130-172.16.5.254
add name=POOL_WLAN_SP ranges=172.16.6.1-172.16.6.253
add name=POOL_LAN_SERVER ranges=172.16.0.130-172.16.0.157
add name=POOL_LAN_VPN ranges=172.16..161-172.16.0.190
#DHCP Server toevoegen
add address-pool=static-only disabled=no interface=VLAN_LAN_MGMT lease-time=7d name=DHCP_LAN_MGMT
add address=172.16.0.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.0.1 netmask=255.255.255.128
add address-pool=POOL_LAN_DATA disabled=no interface=VLAN_LAN_DATA lease-time=7d name=DHCP_LAN_DATA
add address=172.16.1.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.1.1 netmask=255.255.255.0
add address-pool=POOL_WLAN_DATA disabled=no interface=BR_WLAN_DATA lease-time=00:10:00 name=DHCP_WLAN_DATA
add address=172.16.2.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.2.1 netmask=255.255.255.0
add address-pool=POOL_WLAN_GUEST disabled=no interface=BR_WLAN_GUEST lease-time=00:10:00 name=DHCP_WLAN_GUEST
add address=172.16.3.0/24 dns-server=8.8.8.8 gateway=172.16.3.1 netmask=255.255.255.0
add address-pool=POOL_LAN_MFP disabled=no interface=BR_LAN_MFP lease-time=7d name=DHCP_LAN_MFP
add address=172.16.4.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.4.1 netmask=255.255.255.128
add address-pool=POOL_LAN_GAME disabled=no interface=BR_LAN_GAME lease-time=7d name=DHCP_LAN_1_GAME
add address=172.16.4.128/25 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.4.129 netmask=255.255.255.128
add address-pool=POOL_LAN_CAMERA disabled=no interface=BR_LAN_CAMERA lease-time=7d name=DHCP_LAN_CAMERA
add address=172.16.5.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.1.1 netmask=255.255.255.128
add address-pool=POOL_LAN_TVMM disabled=no interface=BR_LAN_TVMM lease-time=7d name=DHCP_LAN_TVMM
add address=172.16.5.128/25 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.5.129 netmask=255.255.255.128
add address-pool=POOL_WLAN_SP disabled=no interface=BR_WLAN_SP lease-time=7d name=DHCP_WLAN_SP
add address=172.16.6.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.6.1 netmask=255.255.255.0
add address-pool=static-only disabled=no interface=VLAN_LAN_SERVER lease-time=7d name=DHCP_LAN_SERVER
add address=172.16.0.128/27 dns-server=172.16.0.130,172.16.0.131 gateway=172.16.0.129 netmask=255.255.255.224
Static leases toevogen aan DHCP Scopes
Management (LAN_MGMT
/ip dhcp-server lease add address=172.16.0.60 mac-address=00:0C:29:04:A3:20 server=DHCP_LAN_MGMT lease-time=7d comment="LibreNMS"
/ip dhcp-server lease add address=172.16.0.120 mac-address=E0:69:95:F4:94:1C server=DHCP_LAN_MGMT lease-time=7d comment="ESXi02 Ring 225"
/ip dhcp-server lease add address=172.16.0.122 mac-address=00:0C:29:66:4F:54 server=DHCP_LAN_MGMT lease-time=7d comment="WIN-MGMT"
/ip dhcp-server lease add address=172.16.0.123 mac-address=00:25:90:F5:1B:82 server=DHCP_LAN_MGMT lease-time=7d comment="ESXi01 Supermicro"
/ip dhcp-server lease add address=172.16.0.124 mac-address=00:25:90:F6:C9:39 server=DHCP_LAN_MGMT lease-time=7d comment="BMC_SuperMicro_Server"
Servers (LAN_SERVER)
/ip dhcp-server lease add address=172.16.0.130 mac-address=00:0c:29:86:52:9a server=DHCP_LAN_SERVER lease-time=7d comment="DC1 Domain Controller"
/ip dhcp-server lease add address=172.16.0.131 mac-address=00:0c:29:D9:DE:F3 server=DHCP_LAN_SERVER lease-time=7d comment="DC2 Domain Controller"
/ip dhcp-server lease add address=172.16.0.132 mac-address=00:0C:29:EE:92:01 server=DHCP_LAN_SERVER lease-time=7d comment="KMS Kerio Mailserver"
/ip dhcp-server lease add address=172.16.0.133 mac-address=00:0c:29:08:78:9e server=DHCP_LAN_SERVER lease-time=7d comment="WDS Windows Deployment"
/ip dhcp-server lease add address=172.16.0.134 mac-address=00:0c:29:df:36:61 server=DHCP_LAN_SERVER lease-time=7d comment="NVR01 Camera Security"
##/ip dhcp-server lease add address=172.16.0.135 mac-address= server=DHCP_LAN_SERVER lease-time=7d comment="SYSLOG01 Syslog server"
##/ip dhcp-server lease add address=172.16.0.136 mac-address= server=DHCP_LAN_SERVER lease-time=7d comment="ZABBIX01 SNMP Server"
/ip dhcp-server lease add address=172.16.0.137 mac-address=00:08:9B:C4:44:06 server=DHCP_LAN_SERVER lease-time=7d comment="NAS01 Ether1"
/ip dhcp-server lease add address=172.16.0.138 mac-address=00:08:9B:CB:C7:3A server=DHCP_LAN_SERVER lease-time=7d comment="NAS02 Ether1"
/ip dhcp-server lease add address=172.16.0.139 mac-address=00:08:9B:CB:C7:3B server=DHCP_LAN_SERVER lease-time=7d comment="NAS02 Ether2"
/ip dhcp-server lease add address=172.16.0.140 mac-address=00:08:9B:CD:D0:49 server=DHCP_LAN_SERVER lease-time=7d comment="NAS03 Ether1"
#/ip dhcp-server lease add address=172.16.0.141 mac-address=00:08:9B:CE:EA:A7 server=DHCP_LAN_SERVER lease-time=7d comment="NAS03 Ether2"
/ip dhcp-server lease add address=172.16.0.142 mac-address=00:08:9B:BF:A0:0E server=DHCP_LAN_SERVER lease-time=7d comment="NAS04 Ether1"
/ip dhcp-server lease add address=172.16.0.143 mac-address=00:08:9B:BF:A0:0F server=DHCP_LAN_SERVER lease-time=7d comment="NAS04 Ether2"
##/ip dhcp-server lease add address=172.16.0.144 mac-address=0C:C4:7A:31:85:81 server=DHCP_LAN_SERVER lease-time=7d comment="ESXi01"
Camera's (LAN_CAMERA)
/ip dhcp-server lease add address=172.16.5.2 mac-address=4C:11:BF:8B:98:48 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM1 Dahua Bullet Woonkamer"
/ip dhcp-server lease add address=172.16.5.3 mac-address=4C:11:BF:8B:99:B8 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM2 Dahua Bullet Slaapkamer Quinn"
/ip dhcp-server lease add address=172.16.5.4 mac-address=00:00:1B:03:CF:A1 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM3 CHD-B1 Spare"
/ip dhcp-server lease add address=172.16.5.5 mac-address=4C:11:BF:BA:C7:C5 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM4 Danua Dome Straat"
/ip dhcp-server lease add address=172.16.5.6 mac-address=4C:11:BF:AC:5B:E8 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM5 Danua Bullet Blokhut DH-IPC-HFW1300SP-0360B"
/ip dhcp-server lease add address=172.16.5.7 mac-address=4C:11:BF:65:D9:99 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM6 Danua Dome PTZ Slaapkamer"
##/ip dhcp-server lease add address=172.16.1.180 mac-address=00:40:8C:AC:51:7D server=DHCP_LAN_CAMERA lease-time=7d comment="Axis M1104"
##/ip dhcp-server lease add address=172.16.1.181 mac-address=00:40:8C:95:D9:83 server=DHCP_LAN_CAMERA lease-time=7d comment="Axis 207 PIR"
##/ip dhcp-server lease add address=172.16.1.182 mac-address=00:40:8C:9E:03:73 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM05"
##/ip dhcp-server lease add address=172.16.1.183 mac-address=00:1F:1F:F9:C5:87 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM06"
##/ip dhcp-server lease add address=172.16.1.184 mac-address=00:08:10:76:C7:3D server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM07"
##/ip dhcp-server lease add address=172.16.1.185 mac-address=4C:11:BF:8B:99:B8 server=DHCP_LAN_CAMERA lease-time=7d comment="IPCAM08"
/ip dhcp-server lease add address=172.16.5.126 mac-address=00:1C:FA:62:9C:07 server=DHCP_LAN_CAMERA lease-time=7d comment="NVR02"
TV en Multimedia apparatuur
/ip dhcp-server lease add address=172.16.5.130 mac-address=00:0F:60:00:D6:75 server=DHCP_LAN_TVMM lease-time=7d comment="Musicbox01 wlan"
/ip dhcp-server lease add address=172.16.5.131 mac-address=B8:27:EB:BE:33:EB server=DHCP_LAN_TVMM lease-time=7d comment="Musicbox01 lan"
/ip dhcp-server lease add address=172.16.5.132 mac-address=B8:27:EB:0E:46:C1 server=DHCP_LAN_TVMM lease-time=7d comment="Raspberry Pi3 Boven"
PC's (LAN_DATA)
/ip dhcp-server lease add address=172.16.1.2 mac-address=6C:F0:49:DD:48:39 server=DHCP_LAN_DATA lease-time=7d comment="PC045 Henk Verheij"
/ip dhcp-server lease add address=172.16.1.3 mac-address=00:0F:FE:AC:9F:3E server=DHCP_LAN_DATA lease-time=7d comment="PC015 Siska Verheij"
/ip dhcp-server lease add address=172.16.1.4 mac-address=00:1B:21:47:B2:4B server=DHCP_LAN_DATA lease-time=7d comment="PC044 Dirk Vlot"
/ip dhcp-server lease add address=172.16.1.5 mac-address=00:1D:60:59:AD:F1 server=DHCP_LAN_DATA lease-time=7d comment="PC032 (Paul Kok)"
Printers en Multifunctionals (LAN_MFP)
/ip dhcp-server lease add address=172.16.4.2 mac-address=64:EB:8C:14:35:3A server=DHCP_LAN_MFP lease-time=7d comment="PR001 Epson XP720"
/ip dhcp-server lease add address=172.16.4.3 mac-address=08:00:37:75:94:ED server=DHCP_LAN_MFP lease-time=7d comment="PR002 Dell 1320C"
DNS Instellen
/ip dns set server=172.16.0.130 allow-remote-requests=yes
Default route toevoegen
/ip route add dst-address=0.0.0.0/0 gateway=172.16.0.125 distance=1 comment="Sonicwall TZ215 Ring 393"
/ip route add dst-address=0.0.0.0/0 gateway=172.16.0.126 distance=2 comment="R02 Mikrotik x86 Ring 225"
SNTP Client configureren
/system ntp client set primary-ntp=172.16.0.130 secondary-ntp=172.16.0.131 enabled=yes
SNMP Server configureren
/snmp set contact="ronald.verheij@skiffkick.nl" location="Ring 393, Pernis, The Netherlands, Zolder" enabled=yes trap-version=2
/snmp community set address=172.16.0.60 numbers=0
SYSLOG Server configureren
/system logging action
set 3 remote=172.16.0.60
/system logging
add action=remote topics=warning
add action=remote topics=info
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=wireless
add action=remote topics=hotspot
Zet de tijdzone goed
/system clock set time-zone-name=Europe/Amsterdam
Setup HOTSPOT server with Radius for GUESTS
Setup Hotspot Profile
/ip hotspot profile add name="WLAN_GUEST" hotspot-address=172.16.3.1 dns-name="" html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap,cookie use-radius=yes radius-accounting=yes
Setup Hotspot Server
/ip hotspot add name="HOTSPOT-WLAN_1_GUEST" interface=VLAN_WLAN_GUEST address-pool="POOL_WLAN_GUEST" profile="WLAN_GUEST" disabled=no
Setup Radius
/radius add service=hotspot address=127.0.0.1 secret="password"
Add user (Manger voor usermanager)
/ip hotspot user add name=admin password="!@49er4All#$"
Einde HOTSPOT config
Enide HOTSPOT config
Instellen van het admin password
/password old-password="" new-password="!@49er4All#$" confirm-new-password="password"
CAPsMAN Configuration
/caps-man datapath
add bridge=BR_WLAN_DATA name=datapath_WLAN_DATA vlan-id=12 vlan-mode=use-tag
add bridge=BR_WLAN_GUEST name=datapath_WLAN_GUEST vlan-id=14 vlan-mode=use-tag
add bridge=BR_LAN_MFP name=datapath_LAN_MFP vlan-id=15 vlan-mode=use-tag
add bridge=BR_LAN_GAME name=datapath_LAN_GAME vlan-id=16 vlan-mode=use-tag
add bridge=BR_LAN_CAMERA name=datapath_LAN_CAMERA vlan-id=17 vlan-mode=use-tag
add bridge=BR_LAN_TVMM name=datapath_LAN_TVMM vlan-id=18 vlan-mode=use-tag
add bridge=BR_WLAN_SP name=datapath_WLAN_SP vlan-id=19 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_WLAN_DATA passphrase=WLAN_DATA
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_WLAN_GUEST passphrase=WLAN_GUEST
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_LAN_MFP passphrase=LAN_MFP01
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_LAN_GAME passphrase=LAN_GAME
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_LAN_CAMERA passphrase=LAN_CAMERA
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_LAN_TVMM passphrase=LAN_TVMM
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=sec_WLAN_SP passphrase=WLAN_SP01
/caps-man configuration
add datapath=datapath_WLAN_DATA mode=ap name=conf_WLAN_DATA security=sec_WLAN_DATA ssid=WLAN_DATA
add datapath=datapath_WLAN_GUEST mode=ap name=conf_WLAN_GUEST security=sec_WLAN_GUEST ssid=WLAN_GUEST
add datapath=datapath_LAN_MFP mode=ap name=conf_LAN_MFP security=sec_LAN_MFP ssid=LAN_MFP
add datapath=datapath_LAN_GAME mode=ap name=conf_LAN_GAME security=sec_LAN_GAME ssid=LAN_GAME
add datapath=datapath_LAN_CAMERA mode=ap name=conf_LAN_CAMERA security=sec_LAN_CAMERA ssid=LAN_CAMERA
add datapath=datapath_LAN_TVMM mode=ap name=conf_LAN_TVMM security=sec_LAN_TVMM ssid=LAN_TVMM
add datapath=datapath_WLAN_SP mode=ap name=conf_WLAN_SP security=sec_WLAN_SP ssid=WLAN_SP
/caps-man access-list
add action=accept comment="MOB01-Ronald Verheij Huawei" disabled=no
mac-address=C4:07:2F:C1:46:E3 ssid-regexp=SP vlan-mode=no-tag
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled
master-configuration=conf_WLAN_DATA name-format=identity
slave-configurations=conf_WLAN_GUEST,conf_LAN_MFP,conf_LAN_GAME,conf_LAN_CAMERA,conf_LAN_TVMM,conf_WLAN_SP
This is the config on a CAP.
Geef het apparaat een identitiet
/system identity set name="Ring 393 AP01"
Maak VLANs
/interface vlan
add name=VLAN_LAN_MGMT interface=ether1 vlan-id=9
add name=VLAN_LAN_DATA interface=ether1 vlan-id=10
add name=VLAN_WLAN_DATA interface=ether1 vlan-id=12
add name=VLAN_WLAN_GUEST interface=ether1 vlan-id=14
add name=VLAN_LAN_MFP interface=ether1 vlan-id=15
add name=VLAN_LAN_GAME interface=ether1 vlan-id=16
add name=VLAN_LAN_CAMERA interface=ether1 vlan-id=17
add name=VLAN_LAN_TVMM interface=ether1 vlan-id=18
add name=VLAN_WLAN_SP interface=ether1 vlan-id=19
Bridge toevogen
add address=172.16.0.2/25 network=172.16.0.0 interface=BR_LAN_MGMT
#CAP Configuration
/interface wireless cap
set interfaces=wlan1 certificate=request discovery-interfaces=ether1
caps-man-address=172.16.0.1 bridge=BR_LAN_MGMT enabled=yes
I’m a little further now.
Situation now.
CAPsMAN configured and direct connect 1 CAP it is working.
But I have also sites that are PtP connected or PTMP connected
I have done this with WDS
CAPsMAP is working over this links but the clients don’t get IP addresses.
I use Local forwarding.
What is or can be wrong now?
When you use local forwarding you shoud connect wlanX interface to network (example bridge) where you want connect.
I have it working now.
The problem was that I setup the PtP and PtmP with NV2 and that doesn’t work
Now I change it to 802.11 and it works.
Now follow problem.
Channels.
I have wAP AC devices and want to set tem for the max speed.
20/40/80 MHz eceee
But Than it say no supported band if I set the width to 80.
Why is that?
Remember wAP AC have 2.4Ghz and 5Ghz radio so you should only select AC on 5Ghz radio. I use automatic 20/40/80Mhz on 5Ghz and working well.
