Hi Guys,
Just on the beginning, I have to admit that I like Mikrotik because of its price, functionality and stability. All these are good, but confiuration is not so simple and sheds a bad light on this platform.
Here is what I have at the moment and here is what I want to get.
1. AS-IS
I have 3 AP from TP-Link which broadcast 3 SSID within 3 different VLANs, connecetd to CRS326-24G-2S+ . Everything works fine.
2. TO-BE
I have decided to change APs to cAP ac because TP-Links are equiped only with 100Mb/s Ethernet cards. So this is what I did:
- I have added eth6, eth7, eth8 to my bridge and made them trunks. New APs are connected to them.
- I have created bridge on each AP and created VLAN to reflect what I have on router/switch. It looks that this works fine because VLAN intefaces on each AP get IPs from DHCP servers running on router/switch.
- I have configured CAPSMAN (CAPSMAN forwarding) in this order:
- 3 sec profiles
- 3 channels (one for each network)
- 3 datapaths (wih VLAN tagging)
- 1 rate config
- 3 configurations (for each SSID)
- 1 provissioning rule (SSID 1 as master, SSID 2 & 3 as slaves)
- I Enabled CAP on each connected AP and they are getting info from CAPSMAN (virtual interfaces are created, but interfaces remain disabled. SSID is showing Mikrotik only on master interfaces. Please look at the picture below.
https://drive.google.com/file/d/1fvsxVW7ZJpM4xP5pr6hMbyc9jfDAWads/view?usp=sharing
Platform wise:
model: CRS326-24G-2S+
firmware-type: dx3230L
factory-firmware: 6.42.7
current-firmware: 6.42.7
upgrade-firmware: 6.47.7
model: RBcAPGi-5acD2nD
revision: r2
serial-number: BECD0C686AC3
firmware-type: ipq4000L
factory-firmware: 6.44
current-firmware: 6.45.9
I will appreciate your help. Please let me know if you came across this problem before and how did you fix it?
