Capsman issue with automation system
Ι set up a network with 20 access points by using Capsman. It is a basic configuration but I am facing some issues.
Firstly, some devices such as Home Wireless phones and wireless doorbell are connected to the wifi for a while and after a few seconds they disconnect. And they are doing this repeatedly.
But devices such as cellphones and laptops are ok.
Secondly, there is an automation system which controls lights and motorized shades. All this devices are connected to a controller, the controller is directly connected to the mikrotik router and the user controls them from an android application. The issue is that when you try to dim the lights it crashes after every few clicks. Also, I am trying to ping the router from a laptop and every few pings a have a high ping. from 2-3ms and then a high ping around 30ms.
