At a friend in the pension is a little embarrassing roaming AP. I got 6x AP RBcAP-2N RB and one SXT Lite2
I got it in the following capacities
Internet === RB2011UiAS-2HnD-IN ==== RB260GSP (3 RBcAP 2n-AP1-3 {}) === ===== RB260GSP (3 RBcAP 2n-1} {Ap4-6 RB SXT Lite2)
Thus I have done Configure the AP to all 7 is the same.
I enabled in wireless CAPsMan
[admin@WIFI_1] > interface wireless cap print
enabled: yes
interfaces: wlan1
certificate: request
lock-to-caps-man: no
discovery-interfaces: ether1
caps-man-addresses:
caps-man-names:
caps-man-certificate-common-names:
bridge: Roaming
requested-certificate: CAP-4C5E0C6E1074
Then I connect to Managment CapsMan and appears like another interfaces
[admin@WIFI_1] > interface wireless print
0 X ;;; managed by CAPsMAN
;;; channel: 2442/20-Ce/gn(20dBm), SSID: NetSkuska, CAPsMAN forwarding
name="wlan1" mtu=1500 mac-address=4C:5E:0C:6E:10:79 arp=enabled interface-type=Atheros AR9300 mode=station ssid="MikroTik" frequency=2412 band=2ghz-b channel-width=20mhz scan-list=default
wireless-protocol=any vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
1 X ;;; managed by CAPsMAN
;;; SSID: NetSkuska, CAPsMAN forwarding
name="wlan5" mtu=1500 mac-address=D4:CA:6D:DE:74:2B arp=enabled interface-type=virtual-AP master-interface=wlan1
[admin@WIFI_1] > ip address print
# ADDRESS NETWORK INTERFACE
0 D 10.255.0.254/24 10.255.0.0 ether1
A core router was specified as follows:
CAPsMAN was specified as follows:
/caps-man security
add authentication-types=wpa-psk encryption=tkip name=WPA passphrase=XXZZZZXX
/caps-man configuration
add channel.band=2ghz-b/g/n channel.width=20 country=slovakia datapath.bridge=Roaming guard-interval=long hide-ssid=no name=cfg1 security.authentication-types=wpa-psk,wpa2-psk security.encryption=aes-ccm \
security.group-encryption=aes-ccm security.passphrase=12fire34 ssid=NetSkuska
/caps-man interface
add arp=enabled configuration=cfg1 disabled=no l2mtu=1600 mac-address=4C:5E:0C:6E:10:79 master-interface=none mtu=1500 name=cap1 radio-mac=4C:5E:0C:6E:10:79
add arp=enabled configuration=cfg1 disabled=no l2mtu=1600 mac-address=D4:CA:6D:DE:74:2B master-interface=none mtu=1500 name=cap2 radio-mac=D4:CA:6D:DE:74:2B
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1 name-prefix=NetAP
/interface bridge print
0 R name="Roaming" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled mac-address=D4:CA:6D:B1:A5:28 protocol-mode=rstp priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m
/ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp1 Roaming dhcp_pool1 10m
This is my configuration, but my problems are as follows:
- I always accompanied only by the device and a 2. Why ? where we make mistakes, it is somehow limited? I’ve also purchase licenses for Level 6 SXT which should I buy Level 3 to upgrade Level 5
- How can I somehow manually add the device?
- Although my blo table managed by capsman, but that’s where the main routers is running manager can not see why?
