CAPsMAN manual channel
Hello everyone. I have a problem with setting manual channels on my CAPs. I have 256 caps running, and i have noticed that they are not selecting different channels but instead just dropping in the same channel.
I tried to set up manual channels, but on most of the CAPs the menu is not available, but on some the menu is available
I have defined the channels, but no difference.
Has anyone else had this problem?
And the last steps to do are:
  • create different configurations using different channels.
  • and then provisioning rules for groups of caps, that will use their own configurations.
