Hi, I have the following Capsman configuration for two wlan interfaces (physical and virtual). I want to make sure that the configuration with physical wlan distributes dhcp, and works like a standard configuration. But virtual wlans worked in bridge mode, and devices connected to them were forwarded inside the network.
I figured out the first one, and it works correctly, dhcp addresses are distributed, and users have access to the Internet. But it’s not clear how to configure the second one so that it works as a bridge.
UDP:I tried adding the ether1 interface to bridge-virtual. But after that, all cap devices are simply turned off
I’m trying to create a wlan network in capsman 2. In order to have a guest network in the first network with the distribution of dhcp addresses. And use the second network as a bridge-station
