I wanted to upgrade my entire WIFI system with CAPSMANN on hAPax3 and 5 x wifi6 hAP ax2.
But unfortunately there is no CAPSMANN on hAPax3.
Can anyone help me?
Kind regards
Alessandro
Look in the wifiwave2 menus.
There is no separate capsman menu section anymore.
https://help.mikrotik.com/docs/display/ROS/WifiWave2#WifiWave2-WifiWave2CAPsMAN
Thankyou very much for your answer.
I have tested it, and it’s not so easy to migrate i have to reconfigure all.
Do anyone have an example of the new capsman configuration?
Alessandro
