Dear All,
Is it possible to have several SSIDs on a single CAP at different frequencies?
This is done with CAPsMAN, but the network analyzer shows that cAP broadcasts the SSID at the same frequency.
Thank you for your help
Dear All,
i experimented and it seems like you cannot change the frequencies as using same radio just broadcasting different SSID
