CAPSMAN - multiple SSID issues after upgrade from v6.49 to v7.7
Dear all,
I have the issue with CAPSMAN after upgrading from v.6.49 to v7.7 ( upgraded routers to CCR2116-12G-4S+, majority of CAPs are rb962uIgs-5hACt2hNt - all manually configured from scratch, I didn’t import the configuration )
I used to have the master CAP with SSID “X” and two slave CAPs with SSIDs “Y” and “Z”, it worked well on the previous OS
After moving to v7.7 I cannot run two slaves at the same time, it seems fine, but it let`s connect only to “Z” but when I try to connect client to “Y” I have info in Windows: “unable to connect to this network”.
If I disable slave CAP with SSID “Z” than I can connect to SSID “Y”, but I still need additional SSID, so there is a chance to avoid this issue, but it`s not perfect. What I have found is that on 2.4GHz radio I can enable only X and Y and on 5GHz I can enable only X and Z. I had that same issue few months ago on another v7.7 router, but there I could use only a two SSIDs and it works.
I will be glad for any suggestions.
Regards,
Nicholas
Update to 7.8 and check again.
No luck with upgrade to v7.8 - after upgrade there is still the same issue
