Hi, I started to use capsman. Everyting is working fine except one thing. I am not able to connect to some ip addresses. Example 192.168.1.77 - port 28252
when I connect through capsman AP, I am not able to connect. When I connect throught different AP, I can connect without problem.
I am enclosing config from capsman server.
Do you have any idea why?
aug/26/2020 16:22:25 by RouterOS 6.47.2
software id = EXDL-YD06
model = 493G
serial number = 66BD05AAC747
add name=bridge1 protocol-mode=none
/interface wirelessmanaged by CAPsMAN
channel: 2412/20-Ce/gn(20dBm), SSID: SSID, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country=“czech republic” frequency=auto ht-supported-mcs=“mcs-0,mcs-1,mcs-
2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mc
s-14,mcs-15” mode=ap-bridge rx-chains=0,1 ssid=SSID tx-chains=0,1
wireless-protocol=802.11
/caps-man configuration
add channel.band=2ghz-b/g/n country=“czech republic” datapath.bridge=bridge1
name=cfg2.4 security.authentication-types=wpa2-psk security.passphrase=
passphrase ssid=SSID
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik wpa-pre-shared-key=key
wpa2-pre-shared-key=key
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg2.4
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=wlan1
/interface detect-internet
set detect-interface-list=all
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=wlan1 list=LAN
/interface wireless capset bridge=bridge1 discovery-interfaces=bridge1 enabled=yes interfaces=wlan1
/ip dhcp-client
/system clock
set time-zone-name=Europe/Prague
