CAPsMAN not able to Provision a New SSID
Hi all,
Not sure what’s going on here. I have CAPsMAN up and running. Has been for some time.
Recently, I decided to go ahead and add a guest SSID, but for some reason, I cannot seem to get it provisioned.
Here’s my config
# feb/20/2019 03:46:16 by RouterOS 6.43.12
# software id = DRFA-DX22
# model = RouterBOARD 3011UiAS
# serial number = 783F07788FB5
/caps-man channel
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=eeCe \
    frequency=5220 name="5GHz 5220" save-selected=no skip-dfs-channels=no
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled \
    frequency=2462 name="2.4Ghz Channel 11"
/caps-man rates
add basic=6Mbps ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
    ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc\
    s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,\
    mcs-20,mcs-21,mcs-22,mcs-23" name=default supported=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs=\
    mcs0-9 vht-supported-mcs=mcs0-9
add basic=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
    s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
    cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
    3" name=default2 supported=\
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-key-update=1h \
    name="Home Standard" passphrase=wifipassword
    name=IoT passphrase=wifipassword
/caps-man configuration
add channel="2.4Ghz Channel 11" country="united kingdom" datapath=IoT \
    installation=indoor mode=ap name=IoT2GHz rx-chains=0,1,2 security=IoT \
    ssid=IoT tx-chains=0,1,2
add channel="2.4Ghz Channel 11" country="united kingdom" datapath=Home \
    installation=indoor mode=ap multicast-helper=full name=Home2GHz \
    security="Home Standard" ssid=Home
add channel="5GHz 5220" channel.save-selected=no country="united kingdom" \
    datapath=Home disconnect-timeout=3s distance=dynamic frame-lifetime=0ms \
    guard-interval=any hw-protection-mode=none hw-retries=7 installation=\
    indoor keepalive-frames=enabled max-sta-count=2007 mode=ap \
    multicast-helper=full name=Home5GHz rx-chains=0,1,2 security=\
    "Home Standard" ssid=Home tx-chains=0,1,2
add channel="2.4Ghz Channel 11" country="united kingdom" datapath=Guest \
    installation=indoor mode=ap name=Guest rx-chains=0,1,2 ssid=Guest \
    tx-chains=0,1,2
/caps-man datapath
add bridge=bridge local-forwarding=yes name=Home vlan-id=2 vlan-mode=use-tag
add bridge=bridge local-forwarding=no name=IoT vlan-id=20 vlan-mode=use-tag
add bridge=bridge local-forwarding=no name=Guest vlan-id=50 vlan-mode=use-tag
/caps-man interface
add configuration=Home2GHz disabled=no l2mtu=1600 mac-address=\
    CC:2D:E0:10:7C:5A master-interface=none name=2GHz-hAPac-1 radio-mac=\
    CC:2D:E0:10:7C:5A radio-name=CC2DE0107C5A
add configuration=IoT2GHz disabled=no l2mtu=1600 mac-address=\
    CE:2D:E0:10:7C:5A master-interface=2GHz-hAPac-1 name=2GHz-hAPac-1-1 \
    radio-mac=00:00:00:00:00:00 radio-name=CE2DE0107C5A
    64:D1:54:56:1F:E3 master-interface=none name="2GHz-wAP AC-1" radio-mac=\
    64:D1:54:56:1F:E3 radio-name=64D154561FE3
    66:D1:54:56:1F:E3 master-interface="2GHz-wAP AC-1" name="2GHz-wAP AC-1-1" \
    radio-mac=00:00:00:00:00:00 radio-name=66D154561FE3
add configuration=Home5GHz disabled=no l2mtu=1600 mac-address=\
    CC:2D:E0:10:7C:59 master-interface=none name=5GHz-hAPac-1 radio-mac=\
    CC:2D:E0:10:7C:59 radio-name=CC2DE0107C59
    64:D1:54:56:1F:E2 master-interface=none name="5GHz-wAP AC-1" radio-mac=\
    64:D1:54:56:1F:E2 radio-name=64D154561FE2
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-enabled hw-supported-modes=ac master-configuration=\
    Home5GHz name-format=prefix-identity name-prefix=5GHz
add action=create-enabled hw-supported-modes=gn master-configuration=\
    Home2GHz name-format=prefix-identity name-prefix=2GHz \
    slave-configurations=IoT2GHz,Guest
The Home & IoT SSID’s provision without any problems, but I cannot get the Guest SSID to appear.
Any thoughts?
