I have a few old RB433 boards scattered around my home with a simple CAPsMAN setup that broadcasts a 5GHz network on the same ssid and channel. All configuration settings default except TX power, frequency and HT chains.
The problem is, sometimes, when i move between two CAPs, they normally reconnect me between eachother as they should, but the newly connected CAP refuses to pass data. Connection strong and stable but no data passthrough. Turning my device’s adapter on/off and reconnecting usually solves the problem, but it is very annoying to know that it is not working properly.
Any tips?
Thanks,
Michael.
What ROS version are you using?
Send export of your capsman server and your wireless devices.
Regards.
Hello and thanks for replying.
I recently updated my CAPsMAN server along with its CAPs to 6.49.7, marked as ‘stable’ for the 433’s.
It seems to be better, but i think its still doing it sometimes.
Here is the config i have on my CAPsMAN server:
# may/15/2023 19:03:27 by RouterOS 6.49.7
# software id = D2PI-7N3S
# model = 433
# serial number = 2939017BE7F8
/caps-man channel
add band=5ghz-a/n control-channel-width=20mhz extension-channel=eC frequency=\
5825 name=channel5 tx-power=25
add band=2ghz-b/g control-channel-width=20mhz extension-channel=disabled \
frequency=2452 name=channel2 tx-power=25
add name=bridge1 protocol-mode=none
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption="" name=securityDOMA \
passphrase=stemidami
/caps-man configuration
add channel=channel5 channel.band=5ghz-a/n channel.control-channel-width=20mhz \
channel.extension-channel=XX channel.frequency=5825 channel.tx-power=27 \
country=no_country_set datapath.client-to-client-forwarding=yes \
datapath.local-forwarding=yes distance=dynamic hw-protection-mode=none \
installation=any mode=ap name=cfg5 rx-chains=0,1 security=securityDOMA \
security.authentication-types=wpa-psk,wpa2-psk security.encryption=aes-ccm \
security.group-encryption=aes-ccm security.passphrase=stemidami ssid=\
vedlejaktajedle5 tx-chains=0,1
add channel=channel2 country=no_country_set \
datapath.client-to-client-forwarding=yes datapath.local-forwarding=yes \
distance=dynamic hw-protection-mode=none installation=any mode=ap name=cfg2 \
security=securityDOMA ssid=tudlenudle2
/caps-man interface
add channel=channel2 channel.band=2ghz-b/g channel.extension-channel=disabled \
channel.tx-power=25 configuration=cfg2 disabled=no l2mtu=1600 mac-address=\
00:0B:6B:2B:99:57 master-interface=none name=cap2.4chodba radio-mac=\
00:0B:6B:2B:99:57 radio-name=000B6B2B9957 security=securityDOMA
add arp=enabled channel=channel2 channel.band=2ghz-b/g/n \
channel.extension-channel=eC channel.tx-power=27 configuration=cfg2 \
disabled=no l2mtu=1600 mac-address=00:0C:42:61:D1:F6 master-interface=none \
mtu=1500 name=cap2.4pracovna radio-mac=00:0C:42:61:D1:F6 radio-name=\
000C4261D1F6
add arp=enabled channel.tx-power=27 configuration=cfg5 disabled=no l2mtu=1600 \
mac-address=00:0C:42:61:D2:2B master-interface=none mtu=1500 name=\
cap5chodba radio-mac=00:0C:42:61:D2:2B radio-name=000C4261D22B
add arp=enabled channel.tx-power=10 configuration=cfg5 disabled=no l2mtu=1600 \
mac-address=00:0C:42:61:D2:1C master-interface=none mtu=1500 name=cap5misa \
radio-mac=00:0C:42:61:D2:1C radio-name=000C4261D21C
add configuration=cfg5 disabled=no l2mtu=1600 mac-address=00:0C:42:61:D2:1F \
master-interface=none name=cap5obyvak radio-mac=00:0C:42:61:D2:1F \
radio-name=000C4261D21F
add arp=enabled channel.tx-power=28 configuration=cfg5 disabled=no l2mtu=1600 \
mac-address=6C:3B:6B:F7:CE:1E master-interface=none mtu=1500 name=\
cap5pracovna radio-mac=6C:3B:6B:F7:CE:1E radio-name=6C3B6BF7CE1E
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=lucka \
supplicant-identity="" wpa-pre-shared-key=luckalucka wpa2-pre-shared-key=\
luckalucka
/interface wireless
# managed by CAPsMAN
# channel: 5825/20-eC/an(10dBm), SSID: vedlejaktajedle5, local forwarding
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-XX \
country="czech republic" disabled=no frequency=auto mode=ap-bridge \
radio-name=RB433AP rx-chains=0,1 security-profile=lucka ssid=MikroTiktak \
station-roaming=enabled tx-chains=0,1 wireless-protocol=nstreme
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
ord,web,sniff,sensitive,api,romon,dude,tikapp"
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-enabled hw-supported-modes=an master-configuration=cfg5
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=all
/interface detect-internet
set internet-interface-list=dynamic lan-interface-list=dynamic \
wan-interface-list=dynamic
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1
/ip dhcp-client
add disabled=no interface=bridge1
/system clock
set time-zone-name=Europe/Prague
/system identity
set name=MisaAP
/system leds
add interface=cap5misa leds=user-led type=interface-transmit
Thanks,
Michael
Did you try to setup an access list to fine tune the accepted signal range and drop when the device is in the low range?
This can prevent to help from “sticky” access point.
https://help.mikrotik.com/docs/display/ROS/Wireless+Interface#WirelessInterface-AccessList
By allowing or disabling forwarding in the rule you force a device to disconnect when the signal in too weak an by doing this the device will be forced to reconnect on the other AP that is having a stronger signal.
Of course to find the sweet spot of the range you will have to do some “survey” of your specific site as the optimal signal range can vary based on the specificity of your building.
Hi and thanks for replying.
That is not the problem, as i often have a strong and stable connection to the newly connected CAP and have the connection stable and clear, but after the connection switches from the weaker one to the stronger one it just sometimes refuses to pass data. I could stand right next to it, have the RSSI -30 dBm, but it just won’t. Anyways, thanks for the function you specified! I didnt know it could do that!
Did you check if your switch shows the host as moved?
