CAPsMAN not provisioning
Hello. I have a problem with CAPsMAN. I tried the settings on a RB2011UIAS with a cAP AC on eth3, to dry-run the settings. But the AP doesn’t connect to CAPsMAN (also, RoMON via the router doesn’t discover the cAP AC).
I’ve set it up based on this video:
https://www.youtube.com/watch?v=LLuGby1ecVM
And adapted to our own needs. Wired employee LAN, guest wifi, wired POS printers+POS iPads.
Anyone see what is wrong?
RB2011UIAS:
# 1970-01-02 01:09:38 by RouterOS 7.14.1
# software id = T1HW-1EBQ
# model = RB2011UiAS-2HnD
# serial number = 7A67079B60A0
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412 name=Ch01_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2437 name=Ch06_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2462 name=Ch11_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2467 name=Ch12_20M_24G tx-power=10
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2472 name=Ch13_20M_24G tx-power=10
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5180 name=Ch36_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5200 name=Ch40_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5220 name=Ch44_20M_5G tx-power=20
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5240 name=Ch48_20M_5G tx-power=20
add name=bridge
set [ find default-name=ether1 ] name=eth1_WAN
set [ find default-name=ether2 ] name=eth2_kontor
set [ find default-name=ether3 ] name=eth3_MikrotikAPs
set [ find default-name=ether4 ] name=eth4_gastrofix_wired
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface vlan
add interface=bridge name=EmployeeLAN_VLAN vlan-id=10
add interface=bridge name=Gastrofix_VLAN vlan-id=30
add interface=bridge name=GuestWIFI_VLAN vlan-id=20
/caps-man datapath
add bridge=bridge local-forwarding=yes name=datapath-gastrofix vlan-id=30 vlan-mode=use-tag
add bridge=bridge local-forwarding=yes name=datapath-guest vlan-id=20 vlan-mode=use-tag
/caps-man rates
add basic=9Mbps name="GN Only - No B rates" supported=9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-basic-mcs=""
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security-gastrofix
add name=security-guest
/caps-man configuration
add channel=Ch36_20M_5G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-5ghz-guest-ch36 security=security-guest ssid=Guest_5GHz
add channel=Ch06_20M_24G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-2.4-gastrofix-ch6 security=security-gastrofix ssid=Gastrofix_2.4GHz
add channel=Ch11_20M_24G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-2.4-gastrofix-ch11 security=security-gastrofix ssid=Gastrofix_2.4GHz
add channel=Ch12_20M_24G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-2.4-gastrofix-ch12 security=security-gastrofix ssid=Gastrofix_2.4GHz
add channel=Ch13_20M_24G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-2.4-gastrofix-ch13 security=security-gastrofix ssid=Gastrofix_2.4GHz
add channel=Ch36_20M_5G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-5ghz-gastrofix-ch36 security=security-gastrofix ssid=Gastrofix_5GHz
add channel=Ch40_20M_5G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-5ghz-gastrofix-ch40 security=security-gastrofix ssid=Gastrofix_5GHz
add channel=Ch48_20M_5G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-5ghz-gastrofix-ch48 security=security-gastrofix ssid=Gastrofix_5GHz
add channel=Ch44_20M_5G country=norway datapath=datapath-gastrofix distance=indoors installation=indoor mode=ap name=cfg-5ghz-gastrofix-ch44 security=security-gastrofix ssid=Gastrofix_5GHz
add channel=Ch06_20M_24G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-2.4-guest-ch6 security=security-guest ssid=Guest_2.4GHz
add channel=Ch11_20M_24G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-2.4-guest-ch11 security=security-guest ssid=Guest_2.4GHz
add channel=Ch12_20M_24G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-2.4-guest-ch12 security=security-guest ssid=Guest_2.4GHz
add channel=Ch13_20M_24G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-2.4-guest-ch13 security=security-guest ssid=Guest_2.4GHz
add channel=Ch40_20M_5G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-5ghz-guest-ch40 security=security-guest ssid=Guest_5GHz
add channel=Ch48_20M_5G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-5ghz-guest-ch48 security=security-guest ssid=Guest_5GHz
add channel=Ch44_20M_5G country=norway datapath=datapath-guest distance=indoors installation=indoor mode=ap name=cfg-5ghz-guest-ch44 security=security-guest ssid=Guest_5GHz
set 2 default-vlan-id=10 vlan-mode=secure
set 3 vlan-mode=secure
set 4 default-vlan-id=30 vlan-mode=secure
set 11 vlan-mode=secure
add name=WAN
add name=LAN
add name=WinboxAccess
add name=gastrofix_dhcp_pool ranges=192.168.7.120-192.168.7.254
add name=guest_dhcp_pool ranges=192.168.88.20-192.168.88.250
add name=dhcp_bridge ranges=192.168.99.2-192.168.99.254
add address-pool=gastrofix_dhcp_pool interface=Gastrofix_VLAN lease-time=23h59m59s name=gastrofix_dhcp_server
add address-pool=guest_dhcp_pool interface=GuestWIFI_VLAN lease-time=2h59m name=guest_dhcp_server
add address-pool=dhcp_bridge interface=bridge name=dhcp1
/port
set 0 name=serial0
/system logging action
set 0 memory-lines=3000
set 1 disk-file-count=10 disk-lines-per-file=3000
/caps-man access-list
add action=accept allow-signal-out-of-range=10s comment="-85..120 accept" disabled=no signal-range=-85..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s comment="-120..-86 reject" disabled=no signal-range=-120..-86 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=eth3_MikrotikAPs
/caps-man provisioning
add action=create-enabled comment=CAP_Bar hw-supported-modes=gn master-configuration=cfg-2.4-gastrofix-ch6 name-format=prefix-identity name-prefix=2.4GHz- slave-configurations=cfg-2.4-guest-ch6
add action=create-enabled comment=CAP_Kontor hw-supported-modes=ac master-configuration=cfg-5ghz-gastrofix-ch36 name-format=prefix-identity name-prefix=5GHz- slave-configurations=cfg-5ghz-guest-ch36
add action=create-enabled comment=CAP_BAR hw-supported-modes=ac master-configuration=cfg-5ghz-gastrofix-ch40 name-format=prefix-identity name-prefix=5GHz- slave-configurations=cfg-5ghz-guest-ch40
add action=create-enabled comment=CAP_Messanin hw-supported-modes=ac master-configuration=cfg-5ghz-gastrofix-ch44 name-format=prefix-identity name-prefix=5GHz- radio-mac=C4:AD:34:9E:DA:B2 slave-configurations=cfg-5ghz-guest-ch44
add action=create-enabled comment=CAP_Chambre hw-supported-modes=ac master-configuration=cfg-5ghz-gastrofix-ch48 name-format=prefix-identity name-prefix=5GHz- slave-configurations=cfg-5ghz-guest-ch48
add action=create-enabled comment=CAP_Kontor hw-supported-modes=gn master-configuration=cfg-2.4-gastrofix-ch11 name-format=prefix-identity name-prefix=2.4GHz- slave-configurations=cfg-2.4-guest-ch11
add action=create-enabled comment=CAP_Chambre hw-supported-modes=gn master-configuration=cfg-2.4-gastrofix-ch12 name-format=prefix-identity name-prefix=2.4GHz- slave-configurations=cfg-2.4-guest-ch12
add action=create-enabled comment=CAP_Messanin hw-supported-modes=gn master-configuration=cfg-2.4-gastrofix-ch13 name-format=prefix-identity name-prefix=2.4GHz- radio-mac=C4:AD:34:9E:DA:B1 slave-configurations=cfg-2.4-guest-ch13
add bridge=bridge interface=eth2_kontor
add bridge=bridge interface=eth3_MikrotikAPs
add bridge=bridge interface=eth4_gastrofix_wired
/interface ethernet switch rule
add dst-address=192.168.1.0/24 new-dst-ports="" ports=eth2_kontor switch=switch1
add dst-address=192.168.7.0/24 new-dst-ports="" ports=eth3_MikrotikAPs,eth4_gastrofix_wired switch=switch1
add dst-address=192.168.88.0/24 new-dst-ports="" ports=eth3_MikrotikAPs switch=switch1
add independent-learning=yes ports=switch1-cpu,eth2_kontor switch=switch1 vlan-id=10
add independent-learning=yes ports=switch1-cpu,eth3_MikrotikAPs switch=switch1 vlan-id=20
add independent-learning=yes ports=switch1-cpu,eth3_MikrotikAPs,eth4_gastrofix_wired switch=switch1 vlan-id=30
add interface=eth1_WAN list=WAN
add interface=eth2_kontor list=LAN
add interface=eth3_MikrotikAPs list=LAN
add interface=Gastrofix_VLAN list=LAN
#hidden IP for forum:
add address=xxxxx/24 interface=eth1_WAN network=xxxx
add address=192.168.1.1/24 interface=EmployeeLAN_VLAN network=192.168.1.0
add address=192.168.7.1/24 interface=Gastrofix_VLAN network=192.168.7.0
add address=192.168.88.1/24 interface=GuestWIFI_VLAN network=192.168.88.0
add address=192.168.99.1/24 interface=bridge network=192.168.99.0
/ip arp
add address=192.168.7.41 interface=Gastrofix_VLAN mac-address=FE:67:3A:11:0F:D0
/ip cloud
set update-time=no
/ip dhcp-server lease
add address=192.168.7.247 client-id=1:78:8a:20:4b:4:a6 mac-address=78:8A:20:4B:04:A6 server=gastrofix_dhcp_server
add address=192.168.7.0/24 comment="DHCP for Gastrofix" dns-server=193.75.75.75,192.168.7.1 gateway=192.168.7.1 netmask=24
add address=192.168.88.0/24 comment="DHCP for Guests" dns-server=193.75.75.75,193.75.75.193 gateway=192.168.88.1
add address=192.168.99.0/24 gateway=192.168.99.1
set allow-remote-requests=yes servers=193.75.75.75,193.75.75.193
/ip firewall address-list
add address=192.168.1.0/24 list=AdminAccess
add address=0.0.0.0/8 list=bogons
add address=172.16.0.0/12 list=bogons
add address=10.0.0.0/8 list=bogons
add address=169.254.0.0/16 list=bogons
add address=127.0.0.0/8 list=bogons
add address=224.0.0.0/4 list=bogons
add address=198.18.0.0/15 list=bogons
add address=192.0.0.0/24 list=bogons
add address=192.0.2.0/24 list=bogons
add address=198.51.100.0/24 list=bogons
add address=203.0.113.0/24 list=bogons
add address=100.64.0.0/10 list=bogons
add address=240.0.0.0/4 list=bogons
add address=192.88.99.0/24 list=bogons
add action=accept chain=input comment="accept established,related" connection-state=established,related
add action=drop chain=input comment="drop invalid" connection-state=invalid
add action=drop chain=forward dst-address=77.66.21.133 in-interface=GuestWIFI_VLAN
add action=accept chain=input comment="Admin Access to Router" src-address-list=AdminAccess
add action=accept chain=input comment="allow LAN to DNS-TCP" dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="allow LAN to DNS-UDP" dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="CAPsMAN accept all local traffic" dst-port=5246,5247 protocol=udp src-address=127.0.0.1
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 log=yes log-prefix="acceot local loopback CAPsMAN"
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address-type=local src-address-type=local
add action=drop chain=input comment="Drop All Else" log-prefix=DROP-FIREWALL
add action=fasttrack-connection chain=forward comment=fasttrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="accept established,related" connection-state=established,related
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=accept chain=forward comment="Allow all LAN (Office, Guest and POS) Traffic to Internet" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="accept out ipsec policy" ipsec-policy=out,ipsec
add action=drop chain=forward comment="DROP ALL Else"
add action=accept chain=forward comment="Allow Port Fowarding if required" connection-nat-state=dstnat
add action=drop chain=forward comment="DROP All Else"
add action=redirect chain=dstnat comment="Force Users to Router DNS -TCP" dst-port=53 protocol=tcp
add action=redirect chain=dstnat comment="Force Users to Router DNS -UDP" dst-port=53 protocol=udp
add action=accept chain=srcnat disabled=yes ipsec-policy=out,none out-interface=eth1_WAN
/ip firewall raw
add action=drop chain=prerouting comment="Drop all non-internet networks" src-address-list=bogons
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes port=2200
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/lcd
set default-screen=stat-slideshow
/system clock
set time-zone-name=Europe/Oslo
/system identity
set name=Router-Kontor
/system logging
add action=disk topics=info,critical,error,info
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=79.160.13.250
add address=162.159.200.1
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server ping
set enabled=no
/tool romon
set enabled=yes secrets=mysecret
cAP AC:
# jan/02/1970 00:02:06 by RouterOS 6.49.10
# software id = JMR2-YE58
# model = RBcAPGi-5acD2nD
# serial number = BECD0BC7D2E7
add admin-mac=C4:AD:34:9E:DA:AF auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan2 ] ssid=MikroTik
/ip hotspot profile
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
/interface wireless cap
set bridge=bridgeLocal discovery-interfaces=bridgeLocal enabled=yes interfaces=wlan1,wlan2
/ip dhcp-client
add comment=defconf disabled=no interface=bridgeLocal
/tool romon
Think your cap isn’t a cap at the moment (not 100% sure about the correct syntax):
/interface wireless cap enabled=yes
It’s enabled (I used the reset configuration → CAPS mode).
Confirmed it with:
[admin@MikroTik] > /interface wireless cap print
                            enabled: yes
                         interfaces: wlan1,wlan2
                        certificate: none
                   lock-to-caps-man: no
               discovery-interfaces: bridgeLocal
                 caps-man-addresses:
                     caps-man-names:
  caps-man-certificate-common-names:
                             bridge: bridgeLocal
                     static-virtual: no
[admin@MikroTik] >
Anyway, I think RoMON should discover the cAP AC, even is CAPsMAN<->CAP wasn’t functioning properly?
I suspect it’s some kind of bridge/port/switch setting I’ve made wrong so something doesn’t see each other or is somewhat isolated?
It likely doesn’t connect because although CAPsMAN is enabled, you have forbid it to run on all interfaces:
You should add some exceptions there, or remove forbid.
You are missing an important part of making VLAN available on a router: VLAN filtering on the bridge.
Please have a look at this topic, that will help you understand configuring VLAN the right way:
I’m stuck. I red the posts, and adapted to the examples, but still no provisioning. Both 2.4 and 5GHz radios showed up under Wireless->CAPsMAN->Radio for 5-10 seconds, but then disappeared. And haven’t been seen since (after many reboots, power downs, unplugging/plugging, etc). And no 2.4/5GHz LED on cAP, or wireless network available.
[admin@MikroTik] > export
# 1970-01-02 00:16:41 by RouterOS 7.14.1
/caps-man channel
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] ssid=Router
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=Employee_VLAN vlan-id=10
add interface=BR1 name=Gastrofix_VLAN vlan-id=30
add interface=BR1 name=GuestWIFI_VLAN vlan-id=20
/caps-man datapath
add bridge=BR1 local-forwarding=yes name=datapath-guest vlan-id=20 vlan-mode=use-tag
add bridge=BR1 local-forwarding=yes name=datapath-gastrofix vlan-id=30 vlan-mode=use-tag
/caps-man rates
/caps-man security
/caps-man interface
add channel=Ch01_20M_24G channel.frequency=2412 configuration=cfg-2.4-gastrofix-ch11 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=74:4D:28:F9:AF:19 master-interface=none name=Gastrofix_2.4GHz-AP_Bar radio-mac=\
    74:4D:28:F9:AF:19 radio-name=744D28F9AF19
add channel=Ch11_20M_24G channel.frequency=2462 configuration=cfg-2.4-gastrofix-ch11 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=74:4D:28:F9:AA:6C master-interface=none name=Gastrofix_2.4GHz-AP_Chambre radio-mac=\
    74:4D:28:F9:AA:6C radio-name=744D28F9AA6C
add channel=Ch06_20M_24G channel.frequency=2437 configuration=cfg-2.4-gastrofix-ch11 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=C4:AD:34:14:34:2A master-interface=none name=Gastrofix_2.4GHz-AP_Kontor radio-mac=\
    C4:AD:34:14:34:2A radio-name=C4AD3414342A
add channel=Ch12_20M_24G channel.frequency=2467 configuration=cfg-2.4-gastrofix-ch11 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=C4:AD:34:9E:DA:B1 master-interface=none name=Gastrofix_2.4GHz-AP_Messanin radio-mac=\
    C4:AD:34:9E:DA:B1 radio-name=C4AD349EDAB1
add channel=Ch40_20M_5G channel.frequency=5200 configuration=cfg-5ghz-guest-ch36 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=74:4D:28:F9:AF:1A master-interface=none name=Gastrofix_5GHz-AP_Bar radio-mac=74:4D:28:F9:AF:1A \
    radio-name=744D28F9AF1A
add channel=Ch48_20M_5G channel.frequency=5240 configuration=cfg-5ghz-guest-ch36 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=74:4D:28:F9:AA:6D master-interface=none name=Gastrofix_5GHz-AP_Chambre radio-mac=74:4D:28:F9:AA:6D \
    radio-name=744D28F9AA6D
add channel=Ch36_20M_5G channel.frequency=5180 configuration=cfg-5ghz-guest-ch36 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=C4:AD:34:14:34:2B master-interface=none name=Gastrofix_5GHz-AP_Kontor radio-mac=C4:AD:34:14:34:2B \
    radio-name=C4AD3414342B
add channel=Ch44_20M_5G channel.frequency=5220 configuration=cfg-5ghz-guest-ch36 configuration.frame-lifetime=10ms disabled=yes l2mtu=1600 mac-address=C4:AD:34:9E:DA:B2 master-interface=none name=Gastrofix_5GHz-AP_Messanin radio-mac=\
    C4:AD:34:9E:DA:B2 radio-name=C4AD349EDAB2
add name=WAN
add name=VLAN
add name=BASE
/port
set 0 name=serial0
/caps-man manager
add action=create-dynamic-enabled comment="2.4GHz 802.11g capable radios" disabled=yes hw-supported-modes=gn master-configuration=cfg-5ghz-guest-ch36 name-format=prefix-identity name-prefix=2.4GHz-
add action=create-dynamic-enabled comment="5GHz 802.11ac capable radios" disabled=yes hw-supported-modes=ac master-configuration=cfg-5ghz-guest-ch36 name-format=prefix-identity name-prefix=5GHz-
add action=create-dynamic-enabled comment="2.4GHz 802.11g capable radios" disabled=yes hw-supported-modes=gn master-configuration=cfg-2.4-gastrofix-ch12 name-format=prefix-identity name-prefix=2.4GHz-
add action=create-dynamic-enabled comment="5GHz 802.11ac capable radios" disabled=yes hw-supported-modes=ac master-configuration=cfg-2.4-gastrofix-ch6 name-format=prefix-identity name-prefix=5GHz-
add bridge=BR1 interface=eth3_MikrotikAPs
add bridge=BR1 interface=eth2_kontor
add bridge=BR1 interface=eth4_gastrofix_wired
/interface bridge vlan
add bridge=BR1 tagged=BR1,eth2_kontor vlan-ids=10
add bridge=BR1 tagged=BR1,eth3_MikrotikAPs vlan-ids=20
add bridge=BR1 tagged=BR1,eth3_MikrotikAPs,eth4_gastrofix_wired vlan-ids=30
add bridge=BR1 tagged=BR1,eth2_kontor,eth3_MikrotikAPs,eth4_gastrofix_wired vlan-ids=99
add interface=Employee_VLAN list=VLAN
add interface=GuestWIFI_VLAN list=VLAN
add interface=Gastrofix_VLAN list=VLAN
add interface=BASE_VLAN list=BASE
add address=192.168.0.1/24 interface=BASE_VLAN network=192.168.0.0
add address=193.90.223.118/24 interface=eth1_WAN network=193.90.223.0
add address=10.0.10.1/24 interface=Employee_VLAN network=10.0.10.0
add address=10.0.10.1/24 interface=GuestWIFI_VLAN network=10.0.10.0
add address=10.0.10.1/24 interface=Gastrofix_VLAN network=10.0.10.0
add action=accept chain=input comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=input comment="Allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="Allow Base_Vlan Full Access" in-interface=BASE_VLAN
add action=drop chain=input comment=Drop
add action=accept chain=forward comment="Allow Estab & Related" connection-state=established,related
add action=accept chain=forward comment="VLAN Internet Access only" connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=masquerade chain=srcnat comment="Default masquerade" out-interface-list=WAN
/system note
Any suggestions?
