I have one problem with router that it is not reaching Internet.
On port 1 it is set up with DHCP client and it gets address.
Ports 2 - 5 are in bridge and bridge has IP 10.10.252.251.
Router acts as DHCP server and gives right addresses and it is also configured as CapsMan which is working as it should.
Here is configuration:
# nov/23/2018 20:20:06 by RouterOS 6.39.1
# software id = LXKL-XSPZ
add name=CapsMan_Bridge
set [ find default-name=ether5 ] poe-out=forced-on
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/caps-man datapath
add bridge=CapsMan_Bridge name=BCDAdria_datapath
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption="" name=BCDAdria_pass \
passphrase=24681357
/caps-man configuration
add country=croatia datapath=BCDAdria_datapath name=BCDAdria security=\
BCDAdria_pass ssid=BCDAdria
add name=CapsMan_DHCP_Pool ranges=10.10.252.101-10.10.252.199
add address-pool=CapsMan_DHCP_Pool disabled=no interface=CapsMan_Bridge name=\
CapsManDHCP
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=CapsMan_Bridge
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=BCDAdria
add bridge=CapsMan_Bridge interface=ether2
add bridge=CapsMan_Bridge interface=ether3
add bridge=CapsMan_Bridge interface=ether4
add bridge=CapsMan_Bridge interface=ether5
/interface l2tp-server server
set caller-id-type=ip-address
add address=10.10.252.251/24 interface=CapsMan_Bridge network=10.10.252.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=10.10.252.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.10.252.251
add action=accept chain=srcnat ipsec-policy=out,none out-interface=ether1
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=BCDAdria_CapsMan
/system routerboard settings
set init-delay=0s
From terminal I can ping 8.8.8.8. but when I connect by LAN or WiFi i get right adress but I can’t ping 8.8.8.8. At same moment I can ping bridge IP and Wan IP (ether1 port).
Routing table says:
0.0.0.0 / 24 ether1 reachable
10.10.252.0 /24 CapsMan_Bridge reachable
192.168.0.0 /24 ether1 reachable
By this it shoul d work but there is no internet either on LAN or WiFi. What I am doing wrong?
