Hi!
I’m struggling with setting up Capsman with two devices, one should be a controller and a cap, the second will we a cap
I don’t see any examples how to do it, is this even possible??
Hi!
Funny you missed i.e. this video:
https://www.youtube.com/watch?v=bHotZT41w3E
Hi!
I use two hapAX2
I followed the video from above.
Before i did a reset on both units.
My CAPsMAN finds the CAP and i can see the two Wifis from the CAP.
On the CAP i can see “managed” by the CAPsMAN.
Now my issue:
on the CAPsMAN, when i click on the wifis from the CAP, the content is “greyed out”. I can´t change anything…
Any suggestions what i did wrong?
Did you, in provisioning, choose create dynamic enabled ? If yes then choose create enabled and you should be able to change settings.
