CAPsMAN or not?
I have the RB4011 with 2 cAP-AC access points and currently have them set up manually without CAPsMAN,
What would be the advantage/disadvantage of running them under CAPsMAN?
Central management, which is definitely an advantage. I switched from CAPsMAN to local configuration which is more stable in my experience.
Big disadvantage of CAPsMAN is when rebooting the router (or other device that is running CAPsMAN) the entire wireless network drops. There seems to be an option to run CAPsMAN redundant.
Why would it be more stable??
One is adding another layer of complexity and for only two capac, I think its a waste of time.
Also using up more CPU…
