CapsMan - pass Comments to RegistrationTable
is somehow possible pass ‘Comments’(RegisteredClients) from Caps to RegistrationTable in CapsManager or create the ‘Comments’ directly in Caps Manager?
Thank You
Regards ZAJDAN
You can have automatic comments in the registration table provided you client devices are in the access list table. From there, give each entry a comment and voila!
Sent from Tapatalk
It worked so far, but not now after an update → v6.46.5 RB760iGS :frowning:
This is bug, or can i check some setting?
Thx,
Tamas
same here, i can’t see in the registration table the ACL comments, hap ac2 6.46.5
Works for me… Checked on two CAPsMAN devices (CCR & RB3011) with 6.46.5.
I updated to 6.46.6 but no change.
  • hap ac2 lite : OK (with 1 CAP)
  • hEX-S: Not OK (with 3 CAPs)
  • another hEX-S OK (with 1 CAP)
    It may be caused by some setting but i don’t know what to check :frowning:
Update:
I did an ACL export and it showed up to some comment with quotation marks some comment without quotation marks :unamused:
I deleted the entire list and I imported all entry with quotation marks.
It works now. :slight_smile:
(One comment contained a question mark, may be the problem caused by updating)
