CAPSMAN possible with multiple SSID
Hello together,
I have via CAPSMAN several Mikrotik-Router running successfully.
On one of the 5 clients I would like to use a different band.
Is it possible to run on this router with different WLAN settings
If anybody knows, how this is possible, I would be happy for any tipp.
Best regards
Michael
What do you mean with “different band”?
Most Mikrotik accesspoints can operate on the 2.4Ghz and 5GHz band simultaneously.
Which hardware do you use?
