Is is possible to configure preamble-mode on interfaces managed by CAPsMAN?
I have two clients with broadcom wifi drivers that have connection problem and I need to configure preamble-more to both.
Regards
Regards
I’ll push this question to the top, because I’m have also this problem. I use a hAP ac as router and a wAP AC as a wifi access point. My idea was, to manage all my wifi interfaces with capsman. Create my configurations, channels and security profiles and provision to the interfaces, but afterwards I can’t connect with my iphones and ipads.
I’m searching a while around and found in the mikrotik wiki, the https://wiki.mikrotik.com/wiki/Manual:Wireless_FAQ, that describe to use the “long” preamble-mode. But I can set this only directly on the interface or have I something oversee in the capsman?
Has anyone the same problem?
Thanks and best regards
Manfred
In your CAPSMAN configuration you could set your HT Guard Interval to long.
