Capsman Problem
Hi;
I am having problems putting a new cap into production on my installation. So far the manager (RB851Ui-2HnD) managed 2 interfaces. Yours (I do not know if it is ok to activate caps on the manager interface to centralize the monitoring) and a 941-2nD (hAP Lite) as cap also. Now I want to add little more caps, but adding the first gives me problems. It is provisioned correctly and tells me that it is being managed by Capsman. But when a client tries to connect to this cap, the manager loses the connection to the interface, indicating the log “00: 00: 00: 00: 00 @ AP Recepcion-1 disconnected, interface disabled”.
The cap finds the manager for IP and both the manager and all caps have version 6.38. The manager’s firmware is 3.33 and hAPs 3.36.
Do you know what may be happening? I have tried with and without certificates and I do not know what else to try. It only happens with the new cap and only fails when trying to connect a client. If there are no clients the cap does not disconnect from the manager …
Greetings and thank you
Translated with google translator
Solved !! After resetting the cAP and reconfiguring it works correctly.
Thanks and best regards
How did you fix it? What were the steps you took? Please advise!
