Hallo,
I have a mikrotik capsman with two cap that works perfect.
Today I added 3 more Cap and I have a problem…in 2G network (for the 3 new cap) Nothing is working, I do not recive IP, internet is not working.
Please hellp.
See attatch.
Thanks.
My Capsman is:
And the remote CAps are ( the 2 cap that are working are in red circle)
Check all mac addresses of your bridges and wifi interfaces. They must be unique, you probably have duplicates.
That was the problem…but this kind of problems should never exist.
Thanks for your help.
Any professional networking device will give you the possibility to change MAC addresses. It’s up to the user to have it changed…or not.
I did a couple hundred caps… I never had duplicate MACs detail me.
You have never restored a backup to another device, as the author did.
Backup is known to copy MAC addresses form the backup device to the restored device … but I see them also in export (.rsc) files with bridges.
You are pretty close to right.
After the few times I have restored a config like that… I went back in and defaulted the MAC addresses.
