Setup:
- Manager: MikroTik hAP be³ Media (board-name "hAP be^3 Media"), RouterOS 7.23.3, radios: wifi1=ipq5332, wifi2/wifi3=qcn9274 (all local, running fine standalone)
- CAP: MikroTik hAP BE Lite (board-name "A42G-HbeP"), RouterOS 7.23.3 (upgraded from 7.22.2 mid-troubleshooting, no change), radios: wifi1/wifi2 = hw-type "mt7992"
- New unified /interface/wifi CAPsMAN (not legacy /caps-man)
What I did:
- Factory reset the hAP BE Lite (Remove Configuration in Winbox), confirmed fully blank (no bridge, no firewall, no IP anywhere).
- On manager: /interface/wifi/capsman set enabled=yes (fresh — was never used before, generated CA/certificate automatically).
- Created two /interface/wifi/configuration profiles (2.4GHz + 5GHz), ssid=AlzolayMK, wpa2-psk/wpa3-psk, ft=yes, country=Chile, datapath.bridge=bridge-Lan.
- Created two /interface/wifi/provisioning rules matched by exact radio-mac (confirmed byte-for-byte against /interface/wifi/radio/print on the CAP itself), action=create-dynamic-enabled, pointing to the profiles above.
- On CAP: /interface/wifi/cap set enabled=yes discovery-interfaces=all.
Result:
- CAP connects successfully every time: /interface/wifi/capsman/remote-cap/print shows state="Ok", correct identity/board-name/serial, connected-time increasing normally.
- CAP's own /interface/wifi/print permanently shows wifi1 and wifi2 as "SSID not set", mode=ap, no security applied — never gets provisioned.
- current-country on the CAP's radios stays at factory default ("Latvia"), never picks up country=Chile from the profile — indicates the config is never actually pushed, not just a display issue.
- Manual /interface/wifi/capsman/remote-cap/provision [find ...] on the specific remote-cap entry: no error, no effect.
- Same manual "Provision" action via Winbox GUI (CAPsMAN > Remote CAP > right-click > Provision): identical no-op.
- No relevant log output at all (topics=wireless,caps) on either the manager or the CAP — no rejection, no error, nothing.
Things ruled out (each tested in isolation, with before/after verification):
- Wrong table (used /interface/wifi/capsman/remote-cap, not /interface/wifi/radio which is local-only on the manager; confirmed /interface/wifi/capsman/provisioning doesn't even exist as a path — provisioning rules live under /interface/wifi/provisioning).
- Band-based matching (supported-bands=2ghz-ax/5ghz-ax) vs exact radio-mac matching — tried both, same result.
- action=create-dynamic-enabled confirmed used throughout (not bare create-dynamic).
- Missing local bridge on the CAP for datapath.bridge to attach to — created /interface/bridge name=bridge-Lan with ether1 as member on the CAP — no change.
- datapath.bridge property itself — removed it entirely from the profile — no change.
- RouterOS version mismatch — CAP was on 7.22.2, upgraded to 7.23.3 to match manager exactly — no change.
- CAP having no IP address — added a DHCP client on the CAP's bridge, confirmed it got a lease from the manager's DHCP server — no change.
- Stale/leftover config from earlier troubleshooting — did a full factory reset and rebuilt everything from scratch in one clean pass — no change.
Working theory: CAPsMAN's provisioning push may not be implemented/working for a MediaTek radio (mt7992) when the manager itself only has Qualcomm radios (ipq5332/qcn9274) locally — i.e. possibly the manager's wifi package doesn't carry whatever driver-specific logic is needed to configure an mt7992 radio remotely, even though the CAPsMAN protocol layer (discovery/connect) is chipset-agnostic and works fine.
Question: is cross-vendor (Qualcomm manager ↔ MediaTek CAP) provisioning supported at all in the current /interface/wifi CAPsMAN implementation? If so, what am I missing? Happy to provide /interface/wifi/radio/print detail from both ends, full config export, or a supout.rif if useful.
