Capsman provisioning
I used create enable on the capsman provisioning rule.
This lets me set specific power levels on and channel in APs once capsmanager picks them up.
The problem is if I need to add a SSID or adjust a security profile… I have to delete the interface and remote cap. Then the AP will update with the new configuration.
So I have to go back through the APs and set the channels and power all over. And all my access lists need to be corrected.
Am I missing something easy here?
When I update the configuration… how can I push that to the APs without the process above.
You are probably looking for: http://wiki.mikrotik.com/wiki/Manual:CAPsMAN#Radio_Provisioning :
“For user’s convenience there are commands that allow the re-execution of the provisioning process for some radio or all radios provided by some AP:”
[admin@CM] > caps-man radio provision 0
