Does CAP system dynamically manage power level and frequency of each controlled AP like other systems do ?
I’m not sure about power level but if you do not set fequency then CAPsman interfaces behave as set to “auto”
Power level is managed using the antenna gain setting on wireless settings of the AP, and the region setting in capsman.
I mean, does CAP system analyze wireless environment then, accordingly, manage itself dynamically channels and power levels for best performance ?
Or is it only a Centralized CONFIGURATION controller (to be tuned by installer only once) ?
