CAPSMAN Questions (dual band usage,provisioning)
Hi
I have two questions regarding CAPSMAN (Router OS 6.46).
First question:
I have configured CAPSMAN with provisioning. When I connect a new AP, it configures my wifi networks automatically. This works great and easy. BUT: I cant change any setting of the CAPs added this way. When I open the CAP Settings in CAPSMAN, I can’t input or change settings. It is for me important to give dedicated frequencies (via channel config) to my APs so they don’t collide. I can change frequency when I configure the CAPs manually, but not when they are provisioned. How, for example, I can set the frequency of an access point using provisioning?
Second question:
I am making tests with the dual band cAP AC (RBcAPGi-5acD2nD). Both bands work great. But it is possible to tell CAPSMAN that clients should prefer 5 GHz band? Clients use the networks they find first. But I think CAPSMAN is able to switch the clients automatically between the cAPs (a kind of roaming). It would be nice that, if in range, 5 GHz is preferred because of the higher data rate.
Thanks in advance.
On the provision tab, if you select create enabled instead of create dynamic enabled, you can edit the settings of the cap under the capsman.
Or you can create different configs for each cap…
This is called band steering, no there is no such feature until now…
