Playing around with a Metal 5 AC. It has possibility to use either 2,4 or 5 GHz radio, but not both simultaneously (no dual-band). Anyway, when I use it without Capsman I am able to configure the 5 Ghz radio properly. When using CapsMan I was confused at start as always 2,4 Ghz was chosen. Finally it worked, if I changed the order for the Provisioning rules, having the 5Ghz as #0…
In case someone else ends up in the same …
