CAPSMAN remote upgrade 3011->non ARM clients
I have a 3011 as a capsmanager and I am trying to upgrade from the capsman interface the clients but I can’t cause 3011 is ARM based and wAP or others need the mips file…
error says that the file mips…npk is not found even if I place it in the root folder of the files. is there a certain folder that I can place the file in order for the CAPSMAN server find it and push it to the clients?
I have 100+ clients and it wouldn’t be wise to do it manually per client
Use the following command (on CAPsMAN) to specify where you put the .npk files:
/caps-man manager set package-path=...
Thx it worked as expected…!!!
I have the same config but can’t get it working. The problem is, that when controlled by caps, devices are losing packets dramatically. When set up as independent radio, it works.. By cable also works. What setup for bridge you have? I have really enough of this… Spent almost 3rd day here for free (family company) and would like to come back home finally…
Here is the problem described:
http://forum.mikrotik.com/t/solved-capsman-rb3011-losing-connection/107342/1
Nevermind, I found the problem. It was not MikroTik’s fault at all.
