Capsman + Repeater + Cap
Hi, I have a hAP AC and a hAP AC lite
My target is to create a CAPsMAN on hap ac in order to manage 2,4 / 5 radios of the same hap ac and 2,5 radio of hap ac lite. The 5 ghz radio of the hap ac lite should be used to connect to 5 ghz CAP of the hap ac.
hAP AP is my router, with dhcp server and all LAN stuffs configured on lan bridge
This is the bridge of hAP AC
add address=192.168.1.1/24 interface="bridge1 - LAN" network=192.168.1.0
add fast-forward=no name="bridge1 - LAN" protocol-mode=none
add bridge="bridge1 - LAN" interface="wlan2 - WiFi 5 GHz" priority=0x50
add bridge="bridge1 - LAN" interface="wlan1 - WiFi 2,4 GHz" priority=0x50
add bridge="bridge1 - LAN" interface="cap2 - Repeater 2,4"
add bridge="bridge1 - LAN" interface="cap1 - Local 2,4"
So, I configured the capsman (with certificates), enabled cap on the 3 radios and configured 5 ghz radio of hap ac lite in station-pseudobridge (station-bridge doesn’t work).
This is the bridge of hAP AC lite
add address=192.168.1.8/24 interface="wlan2 - PTP 5 GHz" network=192.168.1.0
add bridge="bridge1 - LAN" interface=ether1
add bridge="bridge1 - LAN" interface=ether2
add bridge="bridge1 - LAN" interface=ether3
add bridge="bridge1 - LAN" interface=ether4
add bridge="bridge1 - LAN" interface=ether5
add bridge="bridge1 - LAN" interface="wlan2 - PTP 5 GHz"
So capsman starts to send errors: “removing stale connections because of ident conflict”
What’s wrong with the conf?
Right now I managing with hAP AC CAPsMAN only 2,4ghz radios. 5ghz hap ac radio is in ap bridge and 5ghz hap ac lite radio is in station-pseudobridge mode (station-bridge works too). This configuration works, but I would like all of my radios to be controlled by CAPsMAN.
Thanks in advance for any tip.
Simone
Nobody?
