CAPsMAN setup fail - Chateau Pro AX with new wAP ax as repeater wanted
Not sure if the datapath is causing the problem...can you remove that from wifi1 as well? And afterwards, add wifi1 to the bridge port?
That… did the trick.
Now remove cable and AP keeps the IP, I see it from my android in the network.
Capsman doesn’t do a whole lot of managing this cap but oh well.
So, now… does this barebones setup also repeat my guest network? and what’s the best way to check if my devices switch between router an ap?
The backhaul is wireless, everything else works equal to wired backhaul.
In the registration tab you can find at what radio the client is connected to.
